Thread: Bleeding brake system!
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. Bleeding brake system!
    Hi All
    I am new to this forum and wonder if anyone can help out!
    I have a golf mk4 1.9 gttdi
    I've just had to replace my back brake discs and pads - Although never done it before thought i would give it a go.
    Changed the discs and pads fine and then it came to trying to bleed the system. I bought one of those one way valve kit to bleed it and i have done all 4 corners but something is still not right.
    The braking is still really really spongy and the light on my dashboard telling me to check brakepads is still on. i bought new brake fluid and everything and now i just dont know what else to do.
    Is it a case of just bleeding it again? am i doing something wrong? please can anyway help!!!!
  2. Re: Bleeding brake system!
    Dec 2007
    Bleed again, you still have airbubbles.
  3. Re: Bleeding brake system!
    7 Post(s)
    For some reason the VAG systems seem to be very sensitive to the old fashioned pedal pumping method i.e. it doesn't work.
    If you do have another go and it still doesn't work, try a pressure bleeder like the Gunsons Easybleed (from Halfords).
    Hopefully someone like Crasher or A8tech will be along to offer their wealth of experience on this.
  4. Re: Bleeding brake system!
    Mar 2008
    hi im having same problem having just fitted abs pump, ive even pressure bled system using easy bleed kit and have reverse bled using electric pump and have bled bleed screws on master cylinder but still got soft spongy brakes. When engine is not running brakes pump up hard but when started and servo kicks in go soft again, ive now bled system 10 times and am sure there no air in system, has anybody got any more ideas , Thanks.
  5. Re: Bleeding brake system!
    Hyde
    Are you sure you have adjusted the rear brakes correctly ? leaving the pad to far away from the disc will give you a spongy pedal, feeling like there is air in there, it may just be the piston having to travel to far in order to apply the pad to the disc..
  6. Re: Bleeding brake system!
    Sep 2007
    Essex boy in Suffolk
    dont forget the new pads have to bed in aswell, maybe causing some of it.
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  7. Re: Bleeding brake system!
    7 Post(s)
    Quote Originally Posted by cavanagh81 View Post
    If you have changed the abs pump, you need to set it so that it goes into its bleed mode. To do this you need vagcom or similar.
    Look in the vagcom subforum for details of either setting yourself up with it or to find someone with who can help.
  8. Re: Bleeding brake system!
    Mar 2008
    hi thanks for all feedback, i have vag-com software and data cable is it possible to do with this and any idea how ?
  9. Re: Bleeding brake system!
    Mar 2008
    High Wycombe
    I hate bleeding brakes. It's the one thing I'd rather pay someone else to do. One thing I have learnt though is that if the car has a load proportioning valve on the rear axle, it needs holding in the open (heavy car) position while you bleed the rear brakes. Otherwise it reduces the rear brake pressure and you don't get the air out.
    One question: Why did you have to bleed the brakes when changing the pads and discs? I've never had to break the hydraulic circuit when changing pads or discs. Or was it a "While I'm there, I'll replace the brake fluid too"?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  10. Re: Bleeding brake system!
    A, A
    I agree, it one of the jobs I pay to have done.
    I've never bled the system on changing brake pads, just take the lid of the reseviour.
    Just another B7 Estate
  1. Brake System
    By peyton1115 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-11-2007, 11:08 AM
  2. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
  3. a4 tdi bleeding the fuel system HELP
    By sim2101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-07-2007, 01:43 PM
  4. Spongy Brake Pedal - After Bleeding
    By johnboy_78 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-05-2007, 07:59 PM
  5. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
