Thread: Bleeding brake system!
Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. Re: Bleeding brake system!
    #31
    108 Post(s)
    1816 Post(s)
    Quote Originally Posted by jonathanfenton View Post
    Ah right, changed both rear callipers a while back and had a nightmare of a job to bleed it back up. Ended up taking it in and it took them a week to get a pedal back, few months of driving and it's got slowly better
    Where did the calipers come from, new pads and discs?
    Quote Originally Posted by FrenchAudi View Post
    My car has Bosch ABS 5.0
    That is for cars with 5.3 and ESP
  2. Re: Bleeding brake system!
    #32
    Mar 2016
    Minervois, France
    53 Post(s)
    Are you saying my car doesn't have extrasensory perception?
    I'm taking it back!
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Bleeding brake system!
    #33
    Near Blackpool
    48 Post(s)
    Re-conned from pagid. Perhaps should have put some fluid in then to start, I had car jacked in every way possible and had callipers upside side to try to shift the air. They got progressively better over the months ahead
  4. Re: Bleeding brake system!
    #34
    108 Post(s)
    1816 Post(s)
    I have had a lot of problems when I have used recon aluminium calipers, in fact VAG see they should not be rebuilt. Unless stuck I will now only use brand new TRW units or genuine where TRW don't do them. you can tell when a caliper should not be rebuilt, if VAG do not offer an exchange unit then the old one should be discarded.
  5. Re: Bleeding brake system!
    #35
    Near Blackpool
    48 Post(s)
    Fair enough hopefully they will outlast the car!!
  6. Re: Bleeding brake system!
    #36
    Jun 2008
    The golf is a tricky one when it comes to brake bleeding. I've replaced abs pump on Passat b5 and had no issues bleeding the system (without cycling the pump), and have rock hard brakes.
    I changed my front discs, pads and flexi hoses and let the reservoir run dry in the process. After bleeding the system with pressurised bleed kit, I still couldn't get pressure on my pedal (it would be hard when engine off, but when engine turned on, would go to floor). I tried cycling the abs pump as per other threads on this forum, but still couldn't solve it. Ended up taking it to the garage. They spent an hour bleeding it with no progress. Ended up taking off the line between the master cylinder and the abs pump which then allowed them to get the air out the system (this is what they said). Brakes work fine now.
    Moral of the story, don't get air into your system! I won't make that mistake again, not with a golf mk4!
  1. Brake System
    By peyton1115 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-11-2007, 11:08 AM
  2. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
  3. a4 tdi bleeding the fuel system HELP
    By sim2101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-07-2007, 01:43 PM
  4. Spongy Brake Pedal - After Bleeding
    By johnboy_78 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-05-2007, 07:59 PM
  5. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
