Thread: Bleeding brake system!
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. Re: Bleeding brake system!
    #21
    1840 Post(s)
    No, just like everywhere, any way-I don't have any relevant ones to show, all my mechanics do, but not me.
    Regulation is coming to the garage service industry but it won't improve anything, just increase costs for everyone.
  2. Re: Bleeding brake system!
    #22
    Near Blackpool
    48 Post(s)
    Just out of interest how do you bleed the master cylinder?
  3. Re: Bleeding brake system!
    #23
    Mar 2016
    Minervois, France
    53 Post(s)
    Quote Originally Posted by jonathanfenton View Post
    If you are asking me, when I recently renewed the brake fluid I did not bleed the master cylinder as such, as the reservoir level was correct at the beginning, with no air in the m/cyl, and by bleeding fluid from each wheel cylinder in turn the fluid in the m/cyl was also renewed.
    When fitting a new, empty m/cyl on a car without ABS, I fill its reservoir before installing it, then unplug each outlet union on it while pushing the piston gently in by hand with each outlet in turn at the top, to remove as much air as possible. I then install the m/cyl, connect it up, and bleed via each wheel until no more bubbles appear there.
    I have not tried this on a vehicle with ABS, but fear that there will be a possibility of getting a small amount of air into the ABS unit. I assume that if this were to happen I would have to get the unit bled by a VAG dealer.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: Bleeding brake system!
    #24
    1840 Post(s)
    On the Golf 4 with ESP there are two 8-mm bleed nipples on the MC which you release with a 1/4" drive deep 8mm socket on an extension but you have to let the fluid go everywhere as its impossible to get a pipe on. Then rinse (with the cap on, don't ask!)
  5. Re: Bleeding brake system!
    #25
    Mar 2016
    Minervois, France
    53 Post(s)
    Nothing that handy on my A4. But I'm getting used to that.
    If I have to replace the m/cyl I might try bleeding any air in it by loosening the connections at the top of the ABS unit, applying a small pressure to the m/cyl reservoir, and hoping it's not enough pressure to push air into the unit.
  6. Re: Bleeding brake system!
    #26
    1840 Post(s)
    The A4 uses Bosch ABS not ATE and it needs no fancy procedure.
  7. Re: Bleeding brake system!
    #27
    Near Blackpool
    48 Post(s)
    Do you know off the top of your head if you can bleed the master on an A3 8p?
  8. Re: Bleeding brake system!
    #28
    1840 Post(s)
    No, not on the PQ35 platform with Mk60 ABS, the bleeding procedure is also significantly less tortuous than PQ34 with Mk20.
  9. Re: Bleeding brake system!
    #29
    Near Blackpool
    48 Post(s)
    Ah right, changed both rear callipers a while back and had a nightmare of a job to bleed it back up. Ended up taking it in and it took them a week to get a pedal back, few months of driving and it's got slowly better
  10. Re: Bleeding brake system!
    #30
    Mar 2016
    Minervois, France
    53 Post(s)
    [QUOTE=Crasher;1030175]The A4 uses Bosch ABS not ATE and it needs no fancy procedure.[/QUO
    Crasher.
    My car has Bosch ABS 5.0, and I was simply following the statement, which appears twice, in slightly different forms, in the Haynes manual (A4 - 1995 to Feb 2000).
    "If difficulty is experienced in bleeding the braking circuit on models with ABS, this may be due to air being trapped in the ABS hydraulic unit. If this is the case then the vehcle should be taken to a Audi/VAG dealer so that the system can be bled using special electronic test equipment"
    Although this is not mentioned at all in the Bentley manual it made me rather cautious about bleeding air from the m/cyl via the ABS hydraulic unit.
    Maybe it only applies to the Bosch ABS 5.3? - or is just a received myth? (Plenty of those around)
  1. Brake System
    By peyton1115 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-11-2007, 11:08 AM
  2. New Passat - Parking brake system fault warning - Advice please
    By jarnelljones in forum Passat - Archive Topics
    Last Post: 05-09-2007, 07:41 PM
  3. a4 tdi bleeding the fuel system HELP
    By sim2101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-07-2007, 01:43 PM
  4. Spongy Brake Pedal - After Bleeding
    By johnboy_78 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 09-05-2007, 07:59 PM
  5. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
