Thread: O/S inner Rear light Cluster not working
  1. O/S inner Rear light Cluster not working
    Feb 2013
    Uk
    37 Post(s)
    Hi ,
    My rear inner o/s side LED cluster has stopped working.
    I have proved it’s not the cluster at fault as I have tried a brand new cluster.
    when I open / close the boot the Rear cluster lights works for a second or so then go out.
    so I’m assuming there may be a break in the loom some where.
    are the looms prone to failing in certain places. ?
    thabks in advance
  2. Re: O/S inner Rear light Cluster not working
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Hi mate,
    Check the loom at the point where it flexes with the boot and body section. Try wiggling the loom and see if the lights come on. Seen the break before but on a lot older cars.
  3. Re: O/S inner Rear light Cluster not working
    Feb 2013
    Uk
    37 Post(s)
    Hi Morski , thanks.
    I’m guessing the loom is damaged inside the hinge area - assuming the loom is routed through the hinge.
    Found the fault , cable damage on the loom , will now repair .
  1. Rear light cluster not working
    By grahamchet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2017, 03:34 PM
  2. Rear Light Cluster
    By algarve in forum Golf MK7 - 2013 - 2019
    Last Post: 19-04-2013, 06:52 PM
  3. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  4. A6 Rear light cluster
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-03-2009, 08:54 PM
  5. rear light cluster
    By glen poole in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2008, 06:47 PM
