Thread: Which gearbox do I have?
Results 1 to 10 of 11
  1. Which gearbox do I have?
    Jan 2020
    Warrington, cheshire
    Really sorry. Honest Iíve tried to search but Iím just so confused which gearbox I have. There seems to be lots of options that it could be but canít find any direct cross reference.
    My car is a early 2011 a6 c6 avant 2.7 tdi automatic. The codes on the production label say 4f5 0xh and lower down it has CANA. LDU. Not sure which is relevant.
    Reason being the oil line to the transmission cooler split dumping most of the oil and Iím not sure which oil to use to fill it back up with.
    Thanks.
  2. Re: Which gearbox do I have?
    Apr 2014
    SW London / Surrey
    51 Post(s)
    Do you have one of these stickers: Data Sticker/Options Sticker and Engine Codes
  3. Re: Which gearbox do I have?
    Jan 2020
    Yes thatís where got the above codes from. But when search on any of them to try and find which atf I need I get very vague results. 😔
  4. Re: Which gearbox do I have?
    May 2012
    Somerset
    253 Post(s)
    A 7 speed CVT - not a good one ?
  5. Re: Which gearbox do I have?
    Jan 2020
    Quote Originally Posted by Gazwould View Post
    hi. Sorry, So are you saying one of those codes say I defo have the cvt or is it just that it might be the cvt and is rubbish?
    cheers.
  6. Re: Which gearbox do I have?
    Apr 2014
    SW London / Surrey
    51 Post(s)
    Quote Originally Posted by Fleagleuk View Post
    Yes that’s where got the above codes from. But when search on any of them to try and find which atf I need I get very vague results. 
    Any reason to think it's not up to 7.5l (4.5l-5l for change, but no idea if you've drained it completly) of G052180A2 ATF for a 0AN300041R LDU 'box?
    There is a warning "The Continuously Variable Automatic Transmission Multitronic 01J requires a different ATF than shift automatics." Maybe outlets aren't taking heed of that and are listing "regular" ATF wrongly?
  7. Re: Which gearbox do I have?
    Jan 2020
    I know itís dumped a fair bit over my drive way so I have no idea whatís left in side. Luckily it happened just a few hundred meters from the house. But of course there was little traction as the torque converter wasnít pressured. 😔
  8. Re: Which gearbox do I have?
    Jan 2020
    Shefford
    Is it not best to drain it now? At least then youíve done an oil change and get the correct amount in.
  9. Re: Which gearbox do I have?
    Apr 2014
    SW London / Surrey
    51 Post(s)
    Well a litre of fluid would cover a square metre or so. Fix up the leak, drain box as if doing a change to clean container, see how short you are of 5l, put it back in and order enough to top up would be my approach.
  10. Re: Which gearbox do I have?
    Jan 2020
    Sounds like my plan! Thanks.
  1. Question Looking for multitronic gearbox will only one code gearbox work
    By yaza01 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2017, 03:39 PM
  2. Gearbox - No reverse, rattle in neutral- leaking gearbox oil. HELP!!!!!
    By robert1z in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2017, 07:00 PM
  3. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  4. Replies: 1
    Last Post: 15-02-2015, 05:39 PM
  5. Gearbox DFH, will it fit replace my gearbox DFK?
    By red_avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2008, 05:32 PM
