Thread: Windscreen washers not working
  1. Windscreen washers not working
    Jan 2017
    Beds
    43 Post(s)
    Hi all, as per the title. Washer pump not making any noise when engaged. Wipers are still working and come on when you pull the stalk to wash the screen.
    Pump removed and checked and working. Replacement pump put in also not working.
    I can't see a specific fuse for the washers, but have checked every fuse in the dash drivers door side compartment and the fuse box under the bonnet. All fuses are fine.
    Car is a Golf 2011 MK6 1.6tdi convertible.
    Any help appreciated as I'm stumped.
    Sent from my SM-G960F using Tapatalk
  2. Re: Windscreen washers not working
    Jan 2017
    Beds
    43 Post(s)
    Issue sorted! A cable was loose in the connector.
  3. Re: Windscreen washers not working
    Feb 2020
    Bradford
    11 Post(s)
    Frozen screenwash
    Mine did this a couple of years ago irc would not spray screenwash. Left it for a couple of days and it started working again, it has operating reliably since. Presumed the 'ready to use' screenwash had frozen in the lines. In order to avoid a repeat I use 100% concentrate screenwash for winter months.
  4. Re: Windscreen washers not working
    Jan 2017
    Beds
    43 Post(s)
    Quote Originally Posted by Roverfan View Post
    Frozen screenwash
    Thanks for the suggestion. The car is always garaged and I only use concentrated screen wash in the winter months. There was a loose wire in the connector which was why it wasnt working. I've fixed that and now the washers have started working again as they should.
  5. Re: Windscreen washers not working
    Feb 2020
    Bradford
    11 Post(s)
    Good job
    I better have a look at my own connector, likely the same issue
    By Stagnite in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 13-07-2019, 02:41 PM
  2. Windscreen washers.
    By dvd8n in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-02-2014, 02:55 PM
  3. Please Help windscreen washers not working properlly
    By OVI82 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-10-2011, 09:27 PM
  4. windscreen washers not working
    By borakev in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-12-2010, 09:14 PM
  5. windscreen washers
    By predatoress in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-06-2009, 09:12 PM
