Thread: T4 front lights not working
  1. T4 front lights not working
    Jun 2006
    The front lights stopped working on my friends T4 Caravelle last week. The rear lights and front sidelights and dash lights are still functioning. It has a horrid Xenon/HID conversion but have re-made some of the connections but without getting anywhere with the job and as there is no way of testing the bulbs have drawn a blank. lifted the orange fuse and the remaining lights went out so it isnt the fuse at fault. Is there a relay or something or could it be a canbus error ?.
  2. Re: T4 front lights not working
    Jan 2016
    Wiltshire
    I donít think the T4 had canbus so itís unlikely that will be the issue. Can you check the wiring at the lamps to see if power is getting through. I imagine there will be some sort of relay involved in powering these headlights but given the aftermarket conversion itís difficult to speculate where the fault may be.
  3. Re: T4 front lights not working
    Jun 2006
    Thanks. The Caravelle is a 2003 reg model and a 2.5TDI so it may or may not be canbus - I cannot find any definitive information though I have gleaned that part of the system is canbus such as the engine and imobilizer. I have checked for voltage and there is none at the ends of the wires going to the high and low beam and the blue high beam indicator isn't showing at the dash. I need to check if there is voltage at the fuses but can't find any info on the fuse numbers relating to the high and low beam or even whether there are any relays - though I can't find any. All the fuses in the fuse box are intact as I went through every one of them checking resistance with a multimeter. I'm going to go back to original incandescent bulbs but fit relays to help reduce the voltage drop that makes the standard system so weak.
  4. Re: T4 front lights not working
    Apr 2014
    SW London / Surrey
    51 Post(s)
    See if relay 4 is OK: Fuse box Volkswagen Transporter T4.
    The high-beam indicator is straight off of the same supply as to headlamp, so no surprise they are both not working.
    Also maybe F1 / F2 / F11 / F12 - but unlikely all would blow.
  1. Question vw polo 1.2 twist number plate lights n dashboard lights not working
    By gauchosanto in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2017, 07:03 PM
  2. Question Lupo front fog lights not working
    By H&O2008 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-09-2013, 12:49 AM
  3. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  4. Sharan Dim lights not working front and back HELP
    By taaj in forum Touran - Sharan - Caravelle
    Last Post: 17-03-2009, 08:34 PM
  5. led side lights and number plate lights, not working
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 02-04-2008, 07:37 PM
