Thread: Where the Fuel Filter?
Results 1 to 9 of 9
  1. Where the Fuel Filter?
    Port Talbot, South Wales
    44 Post(s)
    I’m having a service and ZF oil and filter change next month on my BiTdi. I bought a new fuel filter for the 36k service but we couldn’t find it so left it for this one. It’s bloody big enough so I should be able to see it but can anyone tell me where to look please?
  2. Re: Where the Fuel Filter?
    Sep 2019
    Coventry uk
    8 Post(s)
    On mine which is the 2.0tdi it was under the plastic trim on the drivers side, uk. Easy enough to change but be quick as some fuel loss. You also need VCDS to prime.
  3. Re: Where the Fuel Filter?
    Jan 2018
    Cheshire UK
    Definitely under the plastic trim directly below the drivers seat (underneath the car) on my 2016 BITDI Allroad.
  4. Re: Where the Fuel Filter?
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Under the driver seat on my 2015 Allroad also, I changed mine last year, you will need T25 torx, 10mm socket, Philips screwdriver and some pliers. Make sure you have the correct filter as there is a couple of different ones with different size inlet and outlet. Its easy to change, too me about 20mins on my driveway, next time will be about 10mins.
    You have to remove the fabric undertray that goes from front wheel to rear wheel, you will then see the filter, sprung pipe clips on each end.
    As above once changed you need to prime the system, this can be done with VCDS or like I did with OBD11. Some people say you dont have to prime but I always have.
    Have plenty or rags handy and also a dish or bag to put old filter into quickly.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  5. Re: Where the Fuel Filter?
    Mar 2009
    Hi JonathanK.Sorry if this is a bit off topic but which garage are you getting to do the oil and filter change on the ZF box and would you mind sharing how much they are charging for it?As for the diesel filter I did this myself on the drive and it’s not to bad.My previous had the filter in the engine bay so much easier to replace.
    2016 A6 BITDI
  6. Re: Where the Fuel Filter?
    44 Post(s)
    Quote Originally Posted by OVI82 View Post
    *******. £230. For ZF original filter and oil plus gasket. That was with a 27% discount offer. TPS wanted £475. I find with Autudoc that if you choose items and put them in your wish list they offer progressively higher discounts. I could have paid about £197 if I’d waited another week but hey ho. As for fitting, I have a friend who works for Merc and they let their fitters use the Worksop out of hours so he does all my servicing at mates rates. The group also has VAG garages so VCDS is always available from one fitter or another. I asked Audi for a price and they gave me the ‘doesn’t need doing, sealed for life sir’ story.
    The ZF8HP box is so widely used now if you look on YouTube there are plenty of videos showing how to do it, although none on an A6 I don’t think.
    Good luck.
  7. Re: Where the Fuel Filter?
    44 Post(s)
    OV182. Check out this video for details on the transmission service
    DIY: C7 Audi ZF 8-Speed Transmission Fluid Change - YouTube
  8. Re: Where the Fuel Filter?
    Mar 2009
    Thanks for the info and the link JonathanK.I have done a gearbox oil change on my previous C6 3.0 and the A4 before that but both had manual gearboxes.Looking at the YouTube clip it seems a bit more involved.This is my first auto and I’m just a bit worried I might mess it up.....I bought the car last year and also intend to keep it for a while,as they are definitely a car to keep.I’ll probably get a specialist to do the gearbox oil.
    2016 A6 BITDI
  9. Re: Where the Fuel Filter?
    44 Post(s)
    Not the kind of job I’d want to do with the car a few feet off the ground. You need a lift or leave it to a specialist. I know membership of a ‘club’ is not a guarantee of quality but this organisation may be worth a look for you.
    Automatic gearbox repairs UK find members for repair Fedauto
  1. Should fuel filter/pollen filter be included as part of service?
    By jasonvaughan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-11-2018, 08:33 PM
  2. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  3. Question 1995 Golf VR6 fuel guage not working + fuel filter location
    By damo1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2008, 10:04 PM
  4. petrol fuel filter, and pollen filter ??
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 02-02-2008, 04:12 PM
  5. petrol fuel filter, and pollen filter ??
    By eddie v twin in forum Archive posts
    Last Post: 30-01-2008, 10:47 AM
