Thread: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
Results 1 to 10 of 11
  1. 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Feb 2020
    Milton Keynes
    Hi guys if anyone can advise I'd be extremely grateful.
    Mrs has a Mk6 golf 1.4 TSI 160bhp on an 09. Cars been good until management light flashed on 2 Fridays back. She took it in and the garage scanned it and said no faults and seems ok. Bring back if the light stays on or you notice anything. So a few days on thhe trot the light flashed on and car driving ok until this Tuesday when she said it felt underpowered. Car went into garage on Thursday and hoped for coil pack/plugs to fix. They tried the coil pack and made no diff they say one cylinder is running at about half compression. Car starts and drives for a few mins then light flashes on and goes off. Oil temp seems to get to temp quick and you can see watching the exhaust, a misfire. Garage doesn't want to touch it and another I called said the same. Not worth the money trying to fix. Maybe a valve and maybe a piston.
    Anyone think it's worth another opinion or had the same issue? What would a replacement cost roughly ? Car has 60k and is mint condition. Pains me to think we can't get something for it or get it up and running for less than its worth. Although reading up it seems to be a common thing with this 160ps version of the engine.
    Thanks! (Crying here!) Dunno what to do
  2. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    35 Post(s)
    774 Post(s)
    CAVD code engine? Broken piston or two... just finishing one in a Scirocco and have to take another in a Beetle apart next week after I have two days off from repairing 1.4 TFSI engines... absolute pieces of junk. This is one of the two destroyed pistons from the Scirocco.
  3. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Feb 2020
    Milton Keynes
    Hi Crasher. Great! So it is a common thing with this engine. Any ideas what a replacement or repair would cost? Or am I better selling it for spares and repair on eBay?
  4. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    35 Post(s)
    774 Post(s)
    The Beetle and Scirocco will come out at around 5k.
  5. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Feb 2020
    Milton Keynes
    Ouch. I've had a couple of prices for engine replacement of 1750 and 2250 but not sure how reliable a replacement is. Shame can't repair our engine. I assume that the car will mot pass not with a misfire, due end March?
  6. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    35 Post(s)
    774 Post(s)
    You can’t even buy the parts for what you have been quoted. If it was not being rebuilt by a VAG technician then the only option I could suggest is a genuine exchange VAG unit which we considered for both the Scirocco and Beetle but decided that at 4746.35 delivered to us in a crate, rebuilding the originals in situ was more cost effective. You need a VAG specialist to help you, these types know and love the marque VAG and will be able to help you, there are lots of us all over the UK so search for one near you.
  7. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Apr 2014
    SW London / Surrey
    51 Post(s)
    A replacement doesn't have to be a rebuild though. Taking a working engine from an accident daamaged vehicle is a lower cost fix, as long as it really is OK and codes into the car. I expect that's what OP has been offered.
  8. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    35 Post(s)
    774 Post(s)
    Second hand engines are very often a disaster and in the case of a 1.4 TFSI I would not even consider it and anyway, we simply refuse to fit second hand engines and gearbox's, over the last 36 years we have had or fingers burnt far to many times. It wasn't such an issue when it was a Golf 1, 2 or 3 but modern engines are so complex just undressing the old and dressing the new engines is a huge job and a used engine is likely to have had many parts removed for separate sale. Not only that but with these engines, they can seem fine until warm and the Beetle outside has 54K miles on it with a full dealer service history, if that was in a scrap yard, it could fool anyone.
  9. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Apr 2014
    SW London / Surrey
    51 Post(s)
    I don't disagree. Just mentioning it as a rationale for why the price can be different. Lots of risk though, especially in a model known to have weak points. It's a chance I'd take to keep a decade old car running if I could see scrapper it was coming out of, and especially if I saw it running in old car.
  10. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    Feb 2020
    Milton Keynes
    Thanks for the info above. Had a quote of 1450 to do the below. You think a scam or legit?
    FULLY SKIMMED & PRESSURE TESTED CYLINDER HEAD
    VALVES RE-SEATED & VALAVE STEM SEALS REPLACED
    POLISHED AND GRINDED CRANKSHAFT
    BRAND NEW MAIN & BIG END BEARINGS
    NEW HEAD GASKET SET & SEALS
    NEW PISTON RINGS SET
    NEW TIMING BELT OR TIMING CHAIN KIT
    BOTTOM CONVERSION SET INSTALLED WHICH INCLUDES FRONT & REAR CRANKSHAFT SEALS REPLACED
  1. Replies: 4
    Last Post: 24-02-2016, 09:22 PM
  2. 1.2 BBM Cylinder 2 no compression
    By Swearingmuffin in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2014, 12:42 AM
  3. No compression in cylinder 2...WHY????
    By andy___b in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2011, 05:13 PM
  4. Low compression on one cylinder
    By ncc1701.js in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 09:27 PM
  5. 1.4 Low compression in cylinder 3
    By eethon in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2009, 09:05 AM
