Thread: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    #11
    Feb 2020
    Milton Keynes
    I have some codes from the car today. Do any help narrow down the root cause of misfire and warning light?
    DTC: P0033,Turbo/Super Charger Bypass Valve Control Circuit / Open
    DTC: P0243,Charge pressure control solenoid valve; Open circuit/short to earth
    DTC: P0563,System Voltage High
  2. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    #12
    Sep 2020
    Odense SV
    Did yours sound like this at idle?
    Udsætter - YouTube
  3. Re: 1.4 TSI 160 Mk6 cylinder compression misfire HELP
    #13
    1840 Post(s)
    They could be ghost codes from previous work such as unplugging the two valves with the ignition on and having the battery on charge, clear the codes and start again.
  1. Replies: 4
    Last Post: 24-02-2016, 09:22 PM
  2. 1.2 BBM Cylinder 2 no compression
    By Swearingmuffin in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2014, 12:42 AM
  3. No compression in cylinder 2...WHY????
    By andy___b in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2011, 05:13 PM
  4. Low compression on one cylinder
    By ncc1701.js in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 09:27 PM
  5. 1.4 Low compression in cylinder 3
    By eethon in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2009, 09:05 AM
