Thread: BPW Engine wont turn
  1. BPW Engine wont turn
    Feb 2020
    spalding
    Have just changed the Turbo on my 2009 A4 Convertible did oil flush and changed started the car ran for 3-4 mins no issue then just stopped just like a seized engine just after engine started with a jump, turned engine off come to restart and it wont turn on starter or if does very tightly. New battery fitted.
    Second part of question if engine gone what is the difference between the BPW engine and the other 2.0 TDi can you use a different bare engine and swap parts across.
  2. Re: BPW Engine wont turn
    Apr 2014
    SW London / Surrey
    51 Post(s)
    How long did you have the flush oil running for? Could it have damaged things? Did you take it out of the sump, or with an extractor?
  3. Re: BPW Engine wont turn
    Feb 2020
    spalding
    was a tinned flush, through the sump. First time in 40 years of doing cars have i had one just stop like this engine wasnt even running 2 minutes and the fact it started again after stopping normally would have removed seized engine. Ill start stripping when stops raining starting with starter motor
  1. Passat 2.0tdi dsg engine wont turn over
    By scanny1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2017, 03:57 PM
  2. Please Help T4 engine wont turn off
    By sully251 in forum The Commercial Range
    Last Post: 10-03-2017, 12:28 AM
  3. Engine wont turn over on the key
    By hallberg in forum Golf MK3 - 1993 - 1999
    Last Post: 16-08-2010, 05:02 PM
  4. ignition light on engine wont turn over
    By wendyjane in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 09:27 PM
  5. engine wont even turn over!
    By icemantaz in forum Leon
    Last Post: 18-04-2008, 10:34 AM
