Thread: oil leak golf mk6 1.4 tsi 2009
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: oil leak golf mk6 1.4 tsi 2009
    #11
    Apr 2016
    peterborough
    The flywheel seal is bolted to the crack of the block.
    Sorry you got me lost there now.. Are you referring to the "crack of the block" as in here...
    as this is where the oil is leaking from. (Either the 2 circles highlighted in blue) or (the 2 red arrows pointing to the line where the top and bottom head meet).
    This part | Flickr
    Thank you.
  2. Re: oil leak golf mk6 1.4 tsi 2009
    #12
    Apr 2016
    peterborough
    Have done some research and I think I have found where it is leaking oil from. This is a diagram of the CAXA engine and it seems to be leaking oil from this area here. It seems like there is a O ring in the block and then the end cap after it... What are the chances this O ring has split and now oil is seeping everywhere?? First time I have heard of this unless it is common?
    leak from here | Flickr
    cylinder head; cylinder head cover; cover for inta... Golf/Variant/4Motion (GOLF) 2009 year Volkswagen EUROPA 103041
  3. Re: oil leak golf mk6 1.4 tsi 2009
    #13
    35 Post(s)
    777 Post(s)
    They are the O rings for the cam locking plate blanks in the head, not the block, for when you do the chains, the are only under crankcase pressure and are huge, we don't even replace them when we do chains. the is a BLP engine but it is the same
  4. Re: oil leak golf mk6 1.4 tsi 2009
    #14
    35 Post(s)
    777 Post(s)
    The “crack” was my iPad predictive text in control, it should have said back...
  5. Re: oil leak golf mk6 1.4 tsi 2009
    #15
    Apr 2016
    peterborough
    Found the culprit...
    Camshaft Adjustment Solenoid Valve Fits Audi A1 2010 2018 A3 2003 20 Febi 107452 4054224074527 | eBay
    Next to the oil filler cap/ ignition coils under the engine casing. The head split from the center piece. The center piece was still stuck in engine (used a screw to get it out) and the long rod bit was also in the engine broken from the center piece! Oil was going every where!
    I used my brothers donor engine to "lend" the part from as VW couldnt seem to find it on their diagram. Its called something along the lines of camshaft adjustment solenoid valve?
  6. Re: oil leak golf mk6 1.4 tsi 2009
    #16
    Apr 2014
    SW London / Surrey
    51 Post(s)
    The 03C... code on the eBay listing should help dealer find it on on the "Electrics / Impulse Sender" page of their diagrams, confirm right variant, etc .
    Can you read that full code from the broken part?
  7. Re: oil leak golf mk6 1.4 tsi 2009
    #17
    35 Post(s)
    777 Post(s)
    We fitted a new aftermarket one of those earlier this week, it was too tight into the O ring bore and stuck, trying to pull it out by hand, the mounting tag snapped off! The spot welds were ****...
    [/url]
    [/url]
  8. Re: oil leak golf mk6 1.4 tsi 2009
    #18
    Apr 2016
    peterborough
    [/url]
    [/url]
    Did seem a pain as mine broke off in 3 parts and the washer/seal was left in the top head of the engine, removed it by tightening a bolt into it and lots of wd40. There was good news and also some bad! I thought the knocking was due to the sensor leaking oil but now that the sensor has been replaced, I am still getting a clunking which seems to be coming from the passenger wheel. I have tried to push on the wheel while on the jack and there is no play in the wheel. When rotating the front passenger wheel backwards by hand, you can hear a clunk noise at 2 certain parts of the rotation of the wheel. Seems like the first clunk starts when I rotate the wheel backwards HALF way and then the next clunk is when the wheel returns back to its original place. When driving, it is very noticeable that the noise is there, sounds more like ticking/clunking. I have replaced the passenger side driveshaft which hasnt made a difference. Is this something to do with the gearbox?
    Thanks.
  9. Re: oil leak golf mk6 1.4 tsi 2009
    #19
    35 Post(s)
    777 Post(s)
    Impossible to say without sampling it in the flesh.
  1. Replies: 8
    Last Post: 05-06-2019, 04:45 PM
  2. VW Golf GTi Edition 30 2009 - Need a second key
    By T3J in forum Golf MK5 - 2004 - 2009
    Last Post: 09-11-2017, 05:06 PM
  3. 2009 MK6 Golf GT TSI 1.4 160
    By leew1988 in forum Golf MK6 - 2009 - 2013
    Last Post: 25-08-2017, 11:07 PM
  4. Question 2009 golf plus oil chage
    By Gazza8374 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-09-2016, 12:15 PM
  5. Please Help Audi A4 Allroad 2009 - sunroof to drivers foot well leak.
    By robdav01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-01-2014, 10:06 PM
