Thread: Camshaft Sensor problems
  1. Camshaft Sensor problems
    Apr 2019
    Rochester
    Hello. I have recently started to get engine warning light on my car after long drives, 30 miles or so on motorway, at 70-75mph. The fault code is cam and crank correlation. No misfires, no drop in performance, nothing. As soon as the car cools, light goes out. However it is only after 30 miles plus driving, which is only about once a month.
    I can drive around town with no problem.
    Could this be (fingers crossed) merely a faulty and overheating crankshaft or camshaft position sensor? or the dreaded chain?
    Mk6 Golf 1.2TSI 105.
    Thank you for advice offered.
  2. Re: Camshaft Sensor problems
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by Stinca View Post
    Fault code scanned with what, a generic scanner?
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Camshaft Sensor problems
    1841 Post(s)
    That suggests a possible oil pressure problem due to sludge in the sump, this allows the VVT system to go out of sync but then come back when the pressure comes back. On that engine I have seen some incredibly thick sump sludge requiring paint stripper to remove it but it clings even worse to the inside of the block, head and cam chain cover. If heavy sludge is found in the sump, great care must be taken when trying to get it out of the rest of the engine as chemical treatments can release it to quickly and in large lumps which block the oil pump pick up and seize the engine. This sludge is a characteristic of highly strung turbo engines using large amounts of aluminium in their construction, cars with ally sumps are even worse, and modern daft interval oil changes.
  1. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  2. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  3. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  4. Question Camshaft Sensor
    By malcolm tripp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2008, 12:44 PM
  5. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
