Thread: Audi A6C Allroad Tdi fail to start problem.
  1. Audi A6C Allroad Tdi fail to start problem.
    Feb 2020
    Hi Guys,
    I'm a new member here and have just acquired this 2.5 Tdi AKE engined Allroad with 230,000kms, bought in non running condition. A bit of history: previous owner told me he left the lights on one night and ran down the battery, so jump started it and left it idling to charge the battery. The coolant fan however has pretty much lost all of its blades (which he had forgotten about). As a result, he says it blew some coolant out. He filled it up and ran it a for few days, ran fine, didnt blow coolant, but one day not long after that it refused to start but turns over fine. He assumed it had blown a head gasket and wanted it gone.
    From what I know of diesels, they dont normally blow head gaskets just sitting and idling so was hopeful that there was some other problem. I have purchased VCDS and it shows
    00542 - Needle lift Sensor (G80): Open or Short to Plus
    I have measured the plug from the #3 injector with my multimeter and have a dead circuit.
    My questions are:
    where is the best online store to purchase a replacement injector?
    Is AUDI - SKODA - VW 059 130 202 G the appropriate injector
    Would this fault stop the car from starting, I see plenty of posts from other owners with this fault but their cars still start.
    Does the fuel pump also need to be primed first?
    Is there something else I might be missing?
    Any help would be much appreciated
    Dale
  2. Re: Audi A6C Allroad Tdi fail to start problem.
    Oct 2019
    Finland
    Quote Originally Posted by dalewrc30 View Post
    Hi Guys,
    My questions are:
    Dale
    If he Ower heat a diesel engine, why you think your heads sits still flat on the block??? Diesel engines can have even more possibilities to get blown cilinder gaskets then petrol, one of the reasons is the compression......
    Sent from my FIG-LX1 using Tapatalk
  3. Re: Audi A6C Allroad Tdi fail to start problem.
    Feb 2020
    Its my experience that diesels dont usually build up heat when sitting idling, unlike petrol engines, however wouldnt it still fire up even if it had warped a head, albeit run roughly?
    Also, would an overheat trigger a fault code or codes?
  4. Re: Audi A6C Allroad Tdi fail to start problem.
    Oct 2019
    Finland
    If your coolant and oil looks good and levels stays where they are then the heads probably are fine
  1. allroad c5 2,5tdi Hot start problem
    By pedra in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-01-2017, 03:21 PM
  2. Touran fail to start
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 28-09-2015, 08:51 PM
  3. Please Help Electrical problem Dash Lights Fail to start
    By oldsparkyman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-07-2012, 03:44 PM
  4. A4 B7 Air conditioning compressor - FAIL - Poss fail - Maybe fail - Has Failed
    By blackgrill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-05-2012, 02:36 PM
  5. 2001 audi allroad 2.5tdi -- AKE engine will not start.
    By hayabusa67 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-05-2011, 10:50 PM
