Thread: Multiple errors
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Multiple errors
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    I would clear them and see what comes back.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    So it turns out - 03-Brake Electronics:
    00290 ABS Wheel speed sensor, rear left - G46 Electrical problem in circuit. Was the cause of the fault codes below,
    09-Central Electronics:
    01497 Blinkers Front Right - M7 Open circuit - Intermittent.
    17-Instrument Cluster:
    00003 Control Module No or Wrong Adaptation.
    19-Diagnostic Data Interface-Gateway:
    01327 ECU for Parking Brake Help - J446 No Signal/No communication - Intermittent.
    53-Parking Brake:
    01316 ABS control module not a plausible signal.
    55-Level Control Xenon Lights:
    01316 ABS Control Module Read Trouble Codes - Intermittent.
    This one was a self explanatory easy fix 76-Parking Help:
    01546 Sensor for parking aid rear mid - left (G204) open circuit/short with ground.
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  3. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    So the codes I'm left with are,
    01-Engine Management:
    U111300 Function limitation due to received malfunction value.
    I've got no idea what this ^ is?
    08-Airco:
    01273 Fresh air blower (V2) Open circuit/Short with ground - Intermittent. This is either the blower motor or blower regulator, just unsure which.
  4. Re: Multiple errors
    Jul 2013
    76 Post(s)
    This is most likely due to the ABS sensor fault that was recorded on the rear left wheel this could be the sensor or the wiring.
    The other fault is as you say if its working ignore it until it fails.( i think its related to motor brushes arcing).
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by dan2485 View Post
    Ok but shouldn't fitting the new sensor erase the code?
  6. Re: Multiple errors
    Jul 2013
    76 Post(s)
    Quote Originally Posted by Rajsta View Post
    Not if the wiring is at fault, check your codes in a few days time.
    Dan
  7. Re: Multiple errors
    #17
    1836 Post(s)
    Even if the sensor is at fault and is changed, the code will not clear. The warning light may eventually go out but t he code will stay.
  1. A6 3.0TDI Avant 2005 ESP Light and multiple VAG-COM errors
    By hydrogenet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-02-2020, 12:37 PM
  2. Replies: 6
    Last Post: 25-07-2019, 07:18 PM
  3. Multiple fault code and errors full read out
    By bashman40 in forum VCDS - General Questions
    Last Post: 08-07-2019, 09:10 AM
  4. Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    By bubak_here in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2018, 01:33 PM
  5. Please help with errors
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2017, 03:44 PM
