Thread: VW Passat 53 plate 1.9TDI Central locking issues
  1. VW Passat 53 plate 1.9TDI Central locking issues
    Feb 2020
    Ilkeston
    Hi, just wondering if someone could point me in the right direction on my passat with the central locking, drivers side and drivers rear passenger locks and unlocks, but complete passenger side, doesn't work at all, neither does the boot and fuel cap button, the passenger door is deadlocked, and after lifting the carpet in the front passenger, i found some water that had built up probably from bad weather due to the window runner in the rear seat being broken, I've checked the CCM too and funny enough that was dry, also did check the circuit board, looked like there had previously been damp but could only see water marks, checked plugs in A post and both connectors are plugged in, does anyone know what colour wires i should be looking for to check for breaks in cable? any help would be appreciated.
  2. Re: VW Passat 53 plate 1.9TDI Central locking issues
    Birmingham
    7 Post(s)
    I have just bought one with similar issues to yours. The ccm had been repaired and was damp again. When I had the plug off it the pins were corroded and dirty. I used a neddle file and some scotch pad to clean the pins and sockets. Also the locks can start to get sticky with age. A bit of wd40 in the mechanism will help. Finally one of my doors has been replaced and the alignment was off. A bit of adjustment sorted that out. Hopefully that helps you out
  1. A3 tdi 2 door 2003 plate central locking issues
    By mortzz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-10-2014, 08:14 PM
  2. Please Help Passat 2002 central locking issues
    By rosco in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-01-2012, 10:52 PM
  3. 54 plate VW Passat central locking problem...stumped!
    By reverendpickles in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2011, 09:24 AM
  4. 53 Plate Audi A4 Avant 1.9tdi Issues
    By paulpingu in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-05-2010, 01:20 PM
  5. Please Help vw touran 55 plate door central locking
    By dinobeano in forum Touran - Sharan - Caravelle
    Last Post: 21-02-2010, 12:26 PM
