Thread: Water in front footwells
  1. Water in front footwells
    Dec 2019
    Oxfordshire
    Has anyone here had water in the front footwells that didn't come in via any of the following areas?
    Right hand side
    • Door seals
    • Bonnet cable grommet
    • Rectangle access panel
    Left hand side
    • Blind/blank grommet
    • Air blower intake duct
    • Door seals
    I don't know of any other way water could get in from the scuttle area.
    There appears to be a lot of water upwards behind the dash but doesn't appear to all be near the ways into the car from the scuttle panels.
    Any ideas? Thanks.
  2. Re: Water in front footwells
    Dec 2019
    Oxfordshire
    First photo shows upwards to the right (pollen filter and blower motor assembly area). There is some sound deadening foam which is also soaked and I'm wondering if it's even possible for water from grommets to track that far over?
    For perspective, the second photo shows the glove box removed from the dash, where the above is upwards to the right of the glove box.
  3. Re: Water in front footwells
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    I'm just drying our Touran out after a leak from sunroof drain. That only affects one side usually though I think. Drains clear under windscreen / wiper area?
  4. Re: Water in front footwells
    Dec 2019
    Oxfordshire
    Quote Originally Posted by VAG-Abound View Post
    I don't have a sun roof, but I checked the drains, scuttle area is completely clear.
    I have completely stripped the scuttle area, wiper motor off, the lot apart from a control box which appears to be hard wired, the wires for that go into the engine bay.
  5. Re: Water in front footwells
    Feb 2020
    Newton abbot
    Hello I’m having the same issue on my mk4 2004 golf tdi seem to be having my foot wells filling up with a lot of water with no obvious signs of where the water could be coming in from don’t have a sunroof so I’m stuck thanks
  6. Re: Water in front footwells
    Mar 2014
    Heater matrix
    Sent from my SM-G950F using Tapatalk
    Using Tapatalk
  7. Re: Water in front footwells
    Mar 2014
    The heater matrix is a small radiator that the water from the engine circulates through for your heating (this is why your heater blows cold air until the engine warms up.)
    Im not sure where they are on a mk5. A 307 has it slap bang in the middle behind the dash console.
    Using Tapatalk
  1. 2005 Seat Alhambra Water in both front footwells
    By campbell1987 in forum Alhambra
    Last Post: 03-05-2018, 02:12 PM
  2. Water in the driver side footwells.. front and rear
    By Boyleyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-07-2011, 01:56 PM
  3. water in front footwells A6 2.0tdi 05
    By oliverm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-09-2010, 06:52 PM
  4. Please Help Water in drivers side front and rear footwells
    By worzel in forum Golf MK5 - 2004 - 2009
    Last Post: 10-12-2009, 05:07 PM
  5. Water in Front Footwells yes again !!! Audi Cabriolet
    By mikie mike in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-11-2007, 03:39 PM
