Thread: Mystery wire in boot
Results 1 to 10 of 11
  1. Mystery wire in boot
    Feb 2011
    United Kingdom Mainland
    Hi, does anyone know what this wire is for? it's with the positive wires that connect to the battery.
    Looks like an airbag plug but not sure where it goes?
    thanks.
  2. Re: Mystery wire in boot
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    How many wires of what colours going into the connector? Might help somone spot it on a wiring diagram. Model year? Trom / feature level?
  3. Re: Mystery wire in boot
    Feb 2011
    its a 2014 (64 plate) A1 S Line 1.6 TDI
    looks like 2 wires - Black/White and Blue/White but will check and confirm tomorrow.
  4. Re: Mystery wire in boot
    108 Post(s)
    1816 Post(s)
    That is the crash detector explosive power disconnect, this is a crash damaged salvage car then? Copart? Near side front impact?
  5. Re: Mystery wire in boot
    Feb 2011
    Hi, yes it is crash damaged, it's my niece's car, so not from copart or anything.
    Just trying to get it back on the road for her.
    So what connects to this plug, is it just a sensor?
    Sent from my SM-G975F using Tapatalk
  6. Re: Mystery wire in boot
    108 Post(s)
    1816 Post(s)
    Yes that is the "battery isolation igniter N253" so the air bags must have triggered and the air bag ECU triggered the pyrotechnic charge in the N253 to disconnect the battery and someone has bodged it to get the car running, it is only A1's with the battery in the boot that have this safety feature. To replace it you fit a new earth cable, the current revised part number is 6C0 915 181 A and costs £62.86 from an Audi main dealer.
  7. Re: Mystery wire in boot
    Feb 2011
    Thanks.
    Bit of a mess this car, My niece had an accident (only had 3rd party insurance) so had it sent to a "garage" for repair. They have done the bodywork but were a bit out their comfort zone with the electrics side of it, so I have volunteered to try and sort the rest of it out. I suspect they have done something with this to get it working.
    The passenger dash airbag went off as well as the passenger seatbelt tensioner.
    Also, I don't think it is the part number you say as that is on the negative side, whereas this plug connects to the positve side of the battery, I can't find one for the A! but I think it's something like these pictures from the web
  8. Re: Mystery wire in boot
    108 Post(s)
    1816 Post(s)
    Can you private message me the REG number please.
  9. Re: Mystery wire in boot
    Feb 2011
    Pm sent.
  10. Re: Mystery wire in boot
    108 Post(s)
    1816 Post(s)
    Built 20-11-14 and a type 8XA BE4 with a CAYC engine and an MZM gearbox, in Glacier white. That part number is ETKA FI suggestion with SDC code search getting it wrong, again. The main part is the "central protection" which if it is missing is VAG part number 8X0 915 459 which is £150.96 or if it is just the "dividing element, pyrotechnic" can be replaced if the rest of the unit is OK, part number 4F0 916 519 and costs £33.86.
  1. Blue wire in N/S of boot
    By JustinM3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2014, 02:19 PM
  2. TT bit of trim in the boot mystery
    By Midge in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 29-09-2014, 10:20 PM
  3. Question vw passat b6 saloon reversing light wire colour in boot
    By PatMcCoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-10-2010, 01:39 PM
  4. Looking for a positive 12v wire in the boot.
    By Smartpainter in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-11-2009, 08:36 PM
  5. Routing wire from battery to boot
    By jkl123 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2009, 08:11 PM
