Thread: Flashing glow plug and limp mode
  1. Flashing glow plug and limp mode
    Dec 2019
    Buckie
    Hi all,
    Had my car about 2 months now and no problems until today.
    Pulled out to overtake and as soon as the car dropped down a gear the car lost most of its power and went into limp mode with the glow plug light flashing.....
    As I pulled over to stop the engine management light is now on and constantly illuminated along side the glow plug flashing and limp mode.
    Anyone had any experience with this situation/problem?
    Car is booked in at my local garage tomorrow to do a diagnostic fault read.
    Thanks.
  2. Re: Flashing glow plug and limp mode
    Dec 2009
    Amesbury, Wiltshire
    18 Post(s)
    Interestingly I had a very similar problem a couple of weeks ago. I was sat through roadworks on a dual carriageway at about 40 mph. When the roadworks ended I pulled out to overtake and accelerated quickly, at which point the glow plug light started flashing (indicating a problem with the engine management) and the car went into limp mode. I pulled off at the next exit and got the manual out which said drive to nearest service centre, but when I switched the car back on the light went off and has stayed off since. I have scanned the car which reported the following which suggested a stuck turbocharger actuator:
    9127 - Actuator Module for Turbocharger 1
    P00AF 00 [096] - Stuck
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 178419 km
    Date: 2020.01.21
    Time: 22:12:02
    Engine speed: 3869.50 /min
    Normed load value: 99.6 %
    Vehicle speed: 106 km/h
    Coolant temperature: 88 °C
    Intake air temperature: 99 °C
    Ambient air pressure: 1030 mbar
    Voltage terminal 30: 14.460 V
    Unlearning counter according OBD: 30
    Turbine actuator 1 bank 1: posit.feedback - Spec.value: 5.00 %
    Turbine actuator 1 bank 1: posit.feedback - Act.value: 43.91 %
    Turbine actuator 1 bank 1: posit.feedback - Offset closed: 0.20 %
    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 0
    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 55
    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 8
    Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt: 2538.4 mV
    Accelerator pedal travel: raw value: 100.00 %
    I have a C7 pre-facelift Ultra - 2.0 tdi.
    Last edited by robes401; 06-02-2020 at 04:45 PM. Reason: clarified glow plug light flashing...
  3. Re: Flashing glow plug and limp mode
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Likely to be a Overboost fault.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: Flashing glow plug and limp mode
    Dec 2019
    Buckie
    Got a loan of a mates generic scanner and got the above message so hopefully nothing terminal....
    Pitch black outside so will give a good look over tomorrow checking for anything obvious although I’m not hugely mechanically minded.
    Thanks for all help so far folks!
  5. Re: Flashing glow plug and limp mode
    Dec 2019
    Buckie
    Thought I’d update incase it ever helps anyone out.....
    In daylight I’ve managed to check over the car with a good mate who’s a mechanic.
    We found the intercooler intake hose had popped off so replaced with a more heavy duty jubilee clip and cleared the code with the diagnostic reader....
    Took it a spirited drove and all is well.
    Thanks.
    0 3 0
  1. Question Flashing glow plug light and limp mode
    By Snoopy2000 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 04-05-2019, 10:19 PM
  2. Question Glow plug light flashing and limp mode.
    By rozzer2005 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2019, 03:41 AM
  3. Flashing glow plug & limp mode
    By nick1212 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-07-2018, 03:22 PM
  4. Glow plug still flashing and limp mode
    By karllap in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2018, 04:23 PM
  5. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
