Thread: Allroad air suspension compressor location
  1. Allroad air suspension compressor location
    Sep 2019
    Chester
    Hi all,
    my suspension has been showing an error on the dash for the last 2 days but yesterday went down to the bump stops. I can’t find anything on line about where the compressor is located for the C7. Can anyone point me in the right direction? I don’t want to be taking it all apart hunting the thing down!
    edit: just got my OBDeleven delivered and have plugged it in to reveal the DTCs of C104600(Level control system static) C104500 (Leak detected in system)
    am I right in thinking a leak has caused the compressor to burn out? I can’t hear it running any more and the fault has only appeared intermittently over the last week, so no real indication that something was seriously wrong until yesterday. It strikes me that compressor failure has happened quickly?
  2. Re: Allroad air suspension compressor location
    Feb 2016
    Blaydon, North east England
    50 Post(s)
    At the front of the spare wheel well, on the outside. Looks to be held up by 5 X M6 nuts (10mm head)
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  3. Re: Allroad air suspension compressor location
    Sep 2019
    Chester
    Thanks Kevtrem, will get under there at the weekend and check it out.
  4. Re: Allroad air suspension compressor location
    Jan 2020
    US
    Has to close by the axle because the leveler has to be close by. Look right by the frame. I better use the right word . By the platform.
    Sent from my moto z3 using Tapatalk
  5. Re: Allroad air suspension compressor location
    May 2008
    31 Post(s)
    Easy to remove, the compressor plug terminal had blown apart on the wifes C7, quick bodge and we were off again.
    I did not notice the plug had been repaired until I got the comp off and on the bench, went to run it off my spare battery, and thats when the terminal fell apart in my hand!
  6. Re: Allroad air suspension compressor location
    Sep 2019
    Chester
    Thanks all, I got it off and stripped it down, noticed some corrosion across the o ring /seal for the compression chamber and cleaned that up. Also changed the relay and the car has stayed up all night in wheel jack mode, so I suspect that the leak was the compressor itself across that seal. If it goes again I’ll try a rebuild kit with a new seal, rest of the pump worked okay.
    It is very easy to get access to it, only difficulty is getting a trolley jack under when the car is slammed to get ground!
  7. Re: Allroad air suspension compressor location
    Sep 2019
    Chester
    Quote Originally Posted by lynalldiscovery View Post
    that’s an ugly repair, so close to the plug too...��
  8. Re: Allroad air suspension compressor location
    Aug 2009
    cheshire
    64 Post(s)
    Quite a common for the repair to be in that location as they mostly 'go' from that point. The yellow wire is the standard audi repair wire. Audi repair instructions say always to replace the relay anyway
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill plates,Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  1. Audi A6 Allroad compressor location
    By Rudimax in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-01-2016, 10:29 PM
  2. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  3. Allroad suspension compressor
    By 27allroadpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 02:09 PM
  4. allroad suspension compressor and vag-com?
    By Grizgut in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-10-2010, 07:41 AM
  5. Allroad Suspension Compressor
    By Boothyboy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2010, 08:50 AM
