Thread: Several dash lights
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Several dash lights
    #11
    Feb 2020
    Stoke on Trent
    Quote Originally Posted by OmegaV6 View Post
    Before changing the battery why not put it on charge for 24 hours?? Make sure it is really fully charged then see what happens ?? A decent modern charger has "repair" options which can, sometimes, sort out battery problems. Worth a try IMHO
    Itís a great thought, donít get me wrong I would do, but I have 3 jobs (Yes three) so itís impossible for me to not have my car that long, Iím not able to get other transport due to location/cost . I know itís going to be costly for a new battery so Iím looking at other less costly options if they are possible. Doesnít seem like anyone has experienced the exact same issue as me so itís difficult
  2. Re: Several dash lights
    #12
    Dec 2007
    Dudley, West Midlands
    Any idea what faults were showing? I dont think your dpf will regen if faults are logged in the engine ecu
    Regards Dean Warren. VCDS owner/user
    Audi A6 Avant 2.5 TDi (AAT 115BHP) 305k Sold
    A6 180 sport 2.5 TDi Quattro Avant 2001. Half Leather 160K New Cams Fitted @ 154K
    A6 C6 3.0 TDi Quattro S-Line Avant with Exclusive Leather SatNav Bluetooth AMI LED and Xenon's
  3. Re: Several dash lights
    #13
    Aug 2018
    Swindon
    8 Post(s)
    Quote Originally Posted by danwheatley View Post
    It’s a great thought, don’t get me wrong I would do, but I have 3 jobs (Yes three) so it’s impossible for me to not have my car that long, I’m not able to get other transport due to location/cost . I know it’s going to be costly for a new battery so I’m looking at other less costly options if they are possible. Doesn’t seem like anyone has experienced the exact same issue as me so it’s difficult
    mmm OK ... do you have access to a digital voltmeter ?? if so check the voltage at the battery before you start in the morning (1), then again, with the engine still running after you've driven for at least an hour (2). Then again after the engine has been turned off for about an hour. (3) If the battery is in decent shape you should see figures of around (1) 12.7 (2) 13.8 (3) 12.7 If you see numbers like (1) 12.5 or less (2) 14.4 (3) less than 12.7 then it is likely the battery is FUBAR..... very "quick and dirty" checks that are not the normal way of checking batteries, but might give an indication of the problem .......
    2014 Audi A6 Allroad (C7, 245bhp)
  4. Re: Several dash lights
    #14
    Apr 2014
    SW London / Surrey
    29 Post(s)
    As above, if still on first battery and it has been abused a bit well worth changing to avoid dead eŮ searches for other causes and an unfourtunate incidend where it won't start one morning.
    I've found tanya.co.uk to be well priced and efficient for delivery.
  5. Re: Several dash lights
    #15
    Feb 2020
    Stoke on Trent
    Quote Originally Posted by dean warren View Post
    I listed the faults in a comment above, canít copy and paste for some reason.
    I did clear the faults but they came back sharpish
  6. Re: Several dash lights
    #16
    Feb 2020
    Stoke on Trent
    Iíll check them out, thankyou
  7. Re: Several dash lights
    #17
    Feb 2020
    Stoke on Trent
    Car now in limp mode!
    Havenít had chance to look at batteries yet....
  8. Re: Several dash lights
    #18
    Feb 2020
    Stoke on Trent
    After scanning the car with it going into limp mode, new codes. Iíve attached the photo hopefully you can view.
    But itís now got DPF restriction - soot accumulation on OBD2/engine
  9. Re: Several dash lights
    #19
    Jan 2013
    Wessex. and Southern France
    74 Post(s)
    Looks like the mass air flow sensor This P0104 diagnostic trouble code (DTC) means that there is an intermittent or erratic fault detected in the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not performing within the normal expected range of the calculated MAF value.
  10. Re: Several dash lights
    #20
    Feb 2020
    Stoke on Trent
    Car has been in for 2 days now still no luck
    Tired of waiting.....
  1. Question Dash Lights
    By Bwithers in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-11-2013, 02:41 PM
  2. dsc, abs dash lights on
    By shadrack in forum Golf MK5 - 2004 - 2009
    Last Post: 05-12-2012, 10:42 PM
  3. dash lights intermitant and interior lights staying on for ages
    By mystic.bertie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2011, 06:27 PM
  4. Dash lights
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 11-02-2010, 08:36 PM
  5. Question Dash lights
    By theberries in forum Golf MK4 - 1999 - 2004
    Last Post: 25-09-2008, 01:59 PM
