Thread: 2007 A6 2.0TDI Injector VCDS values
  1. 2007 A6 2.0TDI Injector VCDS values
    Aug 2015
    Manchester - UK
    Hi all,
    My 2007 A6 Avant 2.0TDI has had a misfire for a while (more noticeable when accelerating, settles down when at a steady speed), my garage thought it was an injector on its way out but wasn't 100% as they didn't test it, they just wanted to replace all the injectors.
    I have checked the injector values on VCDS but need some advice as to what the values say
    Inj. 1 Inj. 2 Inj. 3 Inj. 4
    IDLE = -0.59 -0.56 0.85 0.33
    1500RPM = -0.68 -0.52 0.42 0.78
    2000RPM = -0.78 -0.45 0.38 0.82
    If anyone could shed any light on these values I would appreciate it.
    Steve
  2. Re: 2007 A6 2.0TDI Injector VCDS values
    1840 Post(s)
    Number 3 is suspicious but diagnosing faulty PD injectors is fraught, it is not as if they are cheap or easy to replace.
  1. Question Injector tests - 3.0Tdi - VCDS data
    By swa40 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-12-2016, 03:15 PM
  2. Question Do these VCDS DPF values look okay?
    By ricky92 in forum VCDS - Help Requests
    Last Post: 29-07-2016, 05:21 PM
  3. Please Help Hi all vcds values help
    By paulmaca in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-09-2014, 01:44 AM
  4. Injectors values VCDS
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2012, 06:14 PM
  5. VCDS Reference values
    By johnvw in forum VCDS - General Questions
    Last Post: 03-03-2011, 09:12 AM
