Thread: Touran 1.9tdi pd105 only starts without oil cap
  1. Touran 1.9tdi pd105 only starts without oil cap
    Feb 2020
    Cornwall
    Hi, I'm having problems with my Touran, a few days ago it cut out while driving and had to roll to a lay by. Couldn't get it started and run the battery down. AA attended and attempted to jump start but no luck and was towed home.
    Anyway after attempting a few things, the car will start if the oil cap is removed but as soon as it's put on again, it cuts out.
    I'm trying not to send it to a garage and don't want to buy anything that will be a waste of money and thought there might be an answer here somewhere, please help
  2. Re: Touran 1.9tdi pd105 only starts without oil cap
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Read your other post about nothing coming out of exhaust. Not even with oil cap off? Any sign of where exhaust is then going?
    My first thought is stuck turbo blocking exhaust manifold. What engine code? Model year? Warning lamps? Error code scan?
  3. Re: Touran 1.9tdi pd105 only starts without oil cap
    Sep 2016
    12 Post(s)
    Check the egr to see if it's blocked or held open.
    It recirculates the exhaust gas by diverting into the inlet manifold and should remain closed during starting and Slow running. It may not fire if it's fully open, just kind of "chuff" as you try.
    You could check by removing the air filter and try starting it, check to see if you get prominent exhaust gas present in the filter box.
  1. Audi A3 1.9TDI PD105 Smoking! HELP!!
    By Rob1997 in forum Chat - Anything with wheels
    Last Post: 03-02-2019, 12:05 AM
  2. Question Pd105 to pd140 conversion
    By jordan.dicks97 in forum Audi VW Specialist Centre
    Last Post: 01-01-2018, 10:33 AM
  3. Question Where to get pd105 egr delete kit
    By Golf TD in forum 1.9TDi - Engine
    Last Post: 06-04-2017, 08:50 AM
  4. Touran 1.9TDi DMF
    By Fourbears in forum Touran - Sharan - Caravelle
    Last Post: 04-03-2015, 08:53 AM
  5. A4 1.9tdi 130 starts up facing down hill but on a flat no go :(
    By icebreaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2011, 09:23 PM
