driving car today. dsg dropped out of gear and remained that way, engine was still running, so coasted the car to safety. put lever to park and turned off car. key wouldnt come out of ignition. tried to start car but wont start. all lights which show gear positions flashing on and off on dash. gear lever behaves weirdly. press foot on brake and press button on gear lever to move lever from park to reverse and lever dont move, no foot brake applied, it will move.
no prior signs given before fault, car was behaving itself properly.
cant code scan vehicle properly at present with vagcom as car still stranded and I got picked up. generic code scanner came up with these fault codes in auto gearbox module, 00653 speed select/engage test - no signal. 00194 ignition key extraction lock - signal not plausible.
2009 vw touran with 6 speed dsg gearbox.
