Thread: Yellow oil light on 1.9tdi
  1. Yellow oil light on 1.9tdi
    May 2019
    Louisburgh
    The other night the oil light came on so topped it up with a litre but light stayed on.checked it now and if anything its too high on dipstick so couldn't have been low.its worrying to say the least.I've seen people write about bonnet sensor being a cause but sounds stupid.my bonnet release was stuck a few says prior but sprayed it with wd40 which fixed it.any advice on fix please
    Sent from my 9008X using Tapatalk
  2. Re: Yellow oil light on 1.9tdi
    1840 Post(s)
    Why does it sound stupid? The dash needs to know if the oil has been checked and opening the bonnet is a good indication, after opening the bonnet, if the switch is working it will turn off the yellow warning for 62 miles, I.e. 100Km. If your bonnet switch is faulty, you can replicate the effect by disconnecting the battery for a few seconds.
  3. Re: Yellow oil light on 1.9tdi
    May 2019
    Louisburgh
    Sorted,thanks
  1. Unattached wires near radiator. yellow/grey yellow/brown. horn not working
    By Wombleflump in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-09-2015, 06:49 PM
  2. yellow oil can light
    By peagreenpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 02:27 PM
  3. Attention yellow oil light a4 2.0 tdi 170
    By zakkaz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2011, 08:43 AM
  4. Oil light - yellow
    By SS069 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2010, 01:39 PM
  5. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
