Thread: Dpf sensor short to plus causing glow plug light and eml
  1. Dpf sensor short to plus causing glow plug light and eml
    Dec 2019
    United kingdom
    So I keep on getting a short to plus on my 1.6tdi MK6 Golf for the DPF sensor. When I clear the codes it goes away for about a day and the car feels more responsive better mpg etc. However when the eml light comes back on mpg drops and car feels sluggish and the only error I get is DPF sensor short to plus. I have changed the sensor but it only worked for a few hours before giving the same short to plus error. Any help appreciated
  2. Re: Dpf sensor short to plus causing glow plug light and eml
    Sep 2009
    Stoke on Trent, England
    10 Post(s)
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Dpf sensor short to plus causing glow plug light and eml
    Dec 2019
    United kingdom
    Ive scanned it with VCDS and the only error on the car is In Pic Below
  4. Re: Dpf sensor short to plus causing glow plug light and eml
    Sep 2009
    10 Post(s)
    Its no use posting a picture as it doesn't go bigger to see the error codes.
    Just open the VCDS log file with NotePad, select all text and copy and paste in Code quotes.
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: Yesterday, 07:34 PM
  2. Question Short Dashboard Glow Plug Light Duration
    By indyandy in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2013, 10:45 AM
  3. Question 3,0 TDI glow plug And DPF Sensor Error codes
    By Richie Taylor in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2012, 06:45 AM
  4. Important My Audi a4 1.9tdi problem ESP light and glow plug system warning light
    By Ock00 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2011, 01:33 AM
  5. Glow plug light still on after new plug fitted
    By mkvrnn in forum Golf MK5 - 2004 - 2009
    Last Post: 03-01-2010, 11:15 PM
