Thread: Software Update Failure - Faulty Control Module
  1. Software Update Failure - Faulty Control Module
    Jan 2020
    Fifeshire
    My car's in the workshop on extended sick leave, unable to apply a couple of software fixes. Now been told it may be a faulty control module. I've been told it occasionally happens but it does sound a bit worrying. Has anyone else come across this.
    One of the updates apparently relates to 'front camera' - odd, because AFAIK I don't have a camera (it's the basic Ultra Sport model),so I assume it's just a generic bit of software common across all models.
  2. Re: Software Update Failure - Faulty Control Module
    1836 Post(s)
    Software updates on cars... how many times have you known software updates on a PC to be unreliable? It’s a daft idea and only going to get worse...
  3. Re: Software Update Failure - Faulty Control Module
    Oct 2010
    Huddersfield
    Quote Originally Posted by Glengavel View Post
    Hello there - FYI , All B9 A4s in the UK have a camera, it's at the top of the windscreen and used for pre-sense emergency braking which is standard in the UK amongst other things - Also yes, there is a well known update to the front camera that has been around a year or so now ( Don't ask me what it does!) I guess this has gone wrong in someway in your car.
  4. Re: Software Update Failure - Faulty Control Module
    Jan 2020
    Fifeshire
    Looking at the job sheet, there were two 'updates' - 90K9, which re-sets the temperature range for the front camera heater, and 90K2, which updates software for the instrument cluster. It was the second update that failed, and required a replacement dashboard cluster, which required a few days to-and-fro between the dealer and the factory. Glad I managed to slip that in before the warranty expires next month!
    A bit of Googling reveals that all 90K2 does is correct the displayed time until next service is due.
    https://static.nhtsa.gov/odi/tsbs/20...49135-9999.pdf
  1. S-Software update for engine control unit 23N6
    By Holymoly in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-08-2015, 10:35 AM
  2. Question Parking Brake Module software update
    By B5NUT in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-01-2015, 06:38 PM
  3. comfort control module,(faulty) can this cause battery to go flat
    By nigel63 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-07-2013, 02:03 AM
  4. Instrument control module faulty?
    By hidnmine in forum VCDS - Help Requests
    Last Post: 12-06-2013, 08:49 PM
  5. ccm comfort control module faulty best place to buy one
    By blobby in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2009, 04:10 PM
