Thread: Rear lights
Results 1 to 10 of 13
  1. Rear lights
    Aug 2009
    Near Lanark
    21 Post(s)
    I have a 2014 A6 and the LED has failed in the rear left inner tail light. I've posted in the "wanted" section looking for a new light unit but I wondered if anyone knew if the LED tube light was repairable? It flashes on for a split second when I turn on the lights but then immediately goes off and stays off. All the other lights in the unit are perfect.
    And the wiring has been checked by connecting the opposite side light in to that harness and it powered up perfectly, so I know the fault is within the light.
    Is it repairable?
    Or do I need to replace the whole thing?
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  2. Re: Rear lights
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    Have had the same issue (intermittent) have you taken of the unit... dried it out, cleaned the connectors etc... have people who sec it is die to a faulty gasket and moisture accumulating over time.
    Have had this happen to me ; exact same unit/side.. and it goes away of its own accord...whether that means its moisture or a faulty LED cell I’m not sure...
    Don’t think this is a repairable item... never heard of that.. plus not sure where you would source the replacement LED strip/cell.. good luck..
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Re: Rear lights
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by Gmonster View Post
    Light removed and checked for water ingress....all dry and seal in good condition. Both sides similar.
    Off side connected to near side and it powered all the lights correctly so it's definitely the light unit.
    I don't think it's repairable either but wondered if anyone has success with an attempt.
  4. Rear lights
    Aug 2013
    30 Post(s)
    There are cheaper units available on eBay.. unless you are lucky in picking up a tested second hand OEM unit with a good history etc..
  5. Re: Rear lights
    Aug 2009
    Near Lanark
    21 Post(s)
    Yeah...seen multiple cheap units....but also seen a few pictures of them powered up and it the LED tube would appear to be a series of individual LEDs inside....which isn't what I want.
    I have got the part number and the manufacturer so that helps.
    I've also messaged a few breakers yards but so far no joy.
    I believe it's around £250 from Audi, hence my search for a cheaper unit
  6. Re: Rear lights
    Jul 2016
    Chestfield kent
    81 Post(s)
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
    0 2 0
  7. Re: Rear lights
    Aug 2009
    Near Lanark
    21 Post(s)
    Thanks!!
  8. Rear lights
    Aug 2013
    30 Post(s)
    This should be what the internet is all about... fantastic forum this etc...
    Keep an eye out for me on a future dragons den... promoting small business startup repairing/replacing car LED lighting systems; as suggested by crasher... hah..
    0 2 0
  9. Re: Rear lights
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    "I'd buy that for a dollar!"
  10. Re: Rear lights
    Aug 2009
    Near Lanark
    21 Post(s)
    I've ordered the leds as used in that guide you linked. Arriving Wednesday I think.
    Since the light is broken I'm going to give it a go. My main concern is not breaking the plastic so if the repair fails I can refit to the car and order a replacement light.
    Wish me luck!!
    Sent from my CLT-L29 using Tapatalk
  1. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  2. Please Help right indicator, rear fog light, rear windscreen heater, and brake lights!!!!
    By sutts85 in forum Early Passat Forum - Pre 97
    Last Post: 17-08-2011, 12:13 AM
  3. Brake lights. Rear lights. Not both
    By _sc_ in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-05-2010, 05:22 PM
  4. 2003 Audi A4-Brake Lights & Rear Lights
    By csheehy35 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-11-2008, 10:12 PM
  5. Rear lights and front lights
    By adamk in forum Audi A3 - Archive Topics
    Last Post: 08-03-2008, 08:27 PM
