Sunday,26,January,2020,12:38:53:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
Ross-Tech: Home
-----------------------------Original instrument coding 410F01----------------------------------
VIN: WVGZZZ5NZBW087589 License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
77
VIN: WVGZZZ5NZBW087589 Mileage: 52640km-32708miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
22-AWD -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 FA HW: 03L 907 309 R
Component: R4 2.0l TDI H23 9979
Revision: 42H23--- Serial number: 00000000000000
Coding: 00250012040700080000
Shop #: WSC 00066 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018FA 003012
ROD: EV_ECM20TDI01103L906018ET.rod
VCID: 6ED37BBFB1970C3A37-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 011 F HW: 0BH 927 711 C
Component: DSG DQ500-7A H04 1407
Revision: 00H04V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 2541449324E10F6286-8070
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V22C 0006
Revision: --H28--- Serial number: 00000003638009
Coding: 0031047
Shop #: WSC 01324 020 00200
VCID: 397998E370599B82D2-806C
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000002
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D718CF3AC71A7A2FE-8068
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0046
Revision: BC011001
Coding: 48180A3B8025F1C040080080B400012443513088536D85605C 8000000040
VCID: 3B7582EBBA65A992C0-806E
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14011 012 0203
Serial number: N2955119 °203!
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250111 05 54 0403
Coding: 03304D
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Coding: 000000
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
Component: PARKHILFE PLA H08 0116
Revision: -------- Serial number: 13991101359178
Coding: 109103
VCID: 489FED27FBB3F20A5D-801C
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__201 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PSGQ3XP
Coding: 0012337
VCID: 4C97D1372FCB1E2A79-8018
Subsystem 1 - Serial number: 6332MTS668053530
Subsystem 2 - Serial number: 6342MTS643793520
Subsystem 3 - Serial number: 6351HTS613F7M9KJ
Subsystem 4 - Serial number: 6361HTS6JN18M9KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 AN HW: 5K0 953 569
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20110102200376
Coding: 5880040000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 78FF5DE7C3D3428AED-802C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5N0 920 972 A HW: 5N0 920 972 A
Component: KOMBI H20 0420
Coding: 410F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 3169A0C3602953C26A-8064
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 190111F2001803
Coding: 356003
VCID: 306FA5C763235ACA65-8064
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0420
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB77AF8D7FE01A6B-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2112
Coding: 0000700
VCID: 366393DF414774FA3F-8062
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 5N0 909 144 M
Component: EPS_ZFLS Kl. 203 3201
Revision: 00H20000
Shop #: WSC 01324 785 00200
VCID: 3B7582EB7A65A992C0-806E
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 52645 km
Time Indication: 0
Date: 2014.06.18
Time: 12:34:14
Freeze Frame:
Battery Volts: 12.5 V
DD
Temperature: 14.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0000700
VCID: 377D9EDB464D8DF224-8062
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000136212
Coding: 0023057
VCID: 3365AACB523561D218-8066
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: RCD510 H14 5025
Revision: -----11S Serial number: VWZ4Z3K1158785
Coding: 0500040004
VCID: 65C104936C61CF6246-8030
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01324 020 1012552
VCID: 387F9DE74B53828A2D-806C
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668906382
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
End-------------------------(Elapsed Time: 03:36)--------------------------
