Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 113
  1. 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Feb 2007
    Our 2014 A6 ultra, with 105K on the clock, keeps posting a 19226 P2002 Particulate Bank 1 Efficiency Below Threshold fault code.
    The DPF appears ok on VCDS, both load wise and regular re-gens, and I have also swapped the two differential pressure sensors and re-adapted which hasn't changed anything.
    I've read that the EGR system, in particular the EGR cooler can become clogged over time and so would like to attempt to clean them out to see if it makes a difference.
    I've had a look on youtube and other forums for a guide but am struggling to find this engine. The HP EGR, LP EGR valves and cooler look absolutely buried by the turbo, can anyone offer any advice on how to tackle this job?
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Oct 2019
    Peterborough, England
    23 Post(s)
    Can you post up a photo of the location of the EGR?
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    I've got a new EGR waiting to go in as mine seems to be causing me no end of problems. The Bank 1 error seems to come up almost every time. I've done some work on my A6 (also CNHA) myself but looking at this, it seems the cooling will need to be drained. I've got the workshop manual but it still seems like a difficult job.
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Feb 2007
    I'm told it's among/below this lot.
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    If i'm not mistaken, it's further towards the back and on the bottom half of the DPF. I'll see if I can find a picture.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    Looked at the parts catalogue as it shows where it goes on...this is what I found
    Attachment 36554
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Feb 2007
    Cheers, the attachment link won’t open, but it might be my phone.
    Do you think pulling the arch liner and going in from the side might be the best route?
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Tripletrouble Guest
    I may be way off piste here, but could you have the engine Terracleaned? Would that help at all?
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    To be honest I don't really know. Looking at the assembly from above, it could be possible to try and get to it from the wheel arch liner. I guess there is only one way of finding out right? I seriously think my EGR needs replacing as its causing all sorts of issues.
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    May 2020
    London
    Hey mate, did you manage to get to the EGR Cooler? I’m on the same boat
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
