Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 78
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #61
    Sep 2015
    Forres, Scotland
    19 Post(s)
    Quote Originally Posted by liam walsh View Post
    Some very tricky limited access water pipe clamps down in that area.
    Coolant today went below min again. I top up yesterday and can smell dump when I opened bonnet. And now the best part! Came back home today and plug vcds. And what?
    2 Faults Found:
    20169 - Exhaust Pressure Sensor 1 (G450)
    P0471 00 [096] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    9764 - Exhaust Pressure Sensor 1 (G450)
    P0470 00 [032] - Malfunction
    This faults didn't appear before but now exist! Like you said before this sensor was faulty, but why didn't show before? I will call Audi tomorrow! They probably didn't check faults after they replaced cooler.
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #62
    Dec 2008
    18 Post(s)
    Quote Originally Posted by Sambor11 View Post
    2 Faults Found:
    Freeze Frame:
    I'm not 100% sure because it's a while since I looked at this stuff but ts possible that the G450 is the differential pressure sensor for the dpf and not the MAP sensor I mentioned earlier in the thread. The diff press sensor is an important one for DPF regens so would need looking at ASAP if it is. Is your oil level increasing do you know or have you checked?
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #63
    Dec 2008
    18 Post(s)
    Might be time to consider trading the car in for another while you have no lights on the dash. Early A4 B8.5 adblue cars are not the most reliable as they age. Only I can do 90% of the jobs myself I'd have got rid of mine at this stage. Only today it threw up an engine light due to a dodgy glowplug or wiring.
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #64
    Sep 2015
    Forres, Scotland
    19 Post(s)
    Engine oil is normal
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #65
    Dec 2008
    18 Post(s)
    Keep an eye on it . If the car attempts dpf regen too often diesel can get into the oil.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #66
    Sep 2015
    Forres, Scotland
    19 Post(s)
    Regen is normal as well. Usually after 300 miles. Call them today and see.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #67
    May 2012
    Somerset
    270 Post(s)
    Jesus what a pain this emissions equipment is , I'd get Frank to sort it out .
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #68
    Dec 2008
    18 Post(s)
    Going by past experiences of people that work regularly in dpf deletes / adblu deletes this particular generation of VW group engine do not take wheel to dpf / egr cooler deletes . Within a short space of time after delete the engines end up with bigger issues.
    The Adblu you can delete as long as you dont have the adblu system fault countdown to no restart on the dash but will you make it through mot after I dont know.
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #69
    Sep 2015
    Forres, Scotland
    19 Post(s)
    Should I replace this G450 sensor? Is just one or two?
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #70
    Dec 2008
    18 Post(s)
    Get the dealership to diagnose it . You've had a lot of work done in the area it could be a cracked vacuum hose, bad sensor , loose plug, damaged wire. Tell them you didnt have the problem before they worked on it and now you have . You know this because you did your vcds scans before and after.
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
