Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 113
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    May 2007
    Quote Originally Posted by TheRenegade View Post
    Looked at the parts catalogue as it shows where it goes on...this is what I found
    Attachment 36554
    Where would i find the parts catalogue?
    2015 A6 C7 2.0 Tdi S-Tronic
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    Quote Originally Posted by necstandards View Post
    Original catalogs of auto parts.
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Dec 2008
    19 Post(s)
    I'm in the same EGR cooler P2002 struggle. Did you manage you find a how to guide? That cooler is buried behind the DPF and under the turbo.
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    May 2007
    I couldn't manage to change it, so gave it to a local mechanic that specializes in german cars here in Limerick. He managed to get a second hand throttle body & told me he cleaned the EGR valve located beside the throttle body (~€300). Gave it back but there was still something wrong - no low end power. Eventually after a week, more lights came on.... finally replaced the EGR valve and its running all fine again (~€500). Hope this helps!
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Dec 2008
    19 Post(s)
    Thanks , I'm in limerick too funnily enough.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    Mar 2013
    Leicester
    You guys are lucky...at least someone is willing to do it. There are several garages where I live. There aren't that many VAG specialist garages, the ones that are seem to charge almost dealer-like prices. I saw a video on the internet a few weeks ago where the guy took the DPF off to get to the EGR. It's no tutorial but it gives you an idea of what you have to do. He took the whole front end off! If I had a week off work maybe I could have a shot at it but it's a big job regardless. One guy told me that he has to take the subframe off to get to it from underneath . Then when I told him to go ahead and do it, he said he didn't have the "manpower" to do it as it needed a second pair of hands.
    However, there doesn't seem to be any issues with mine at the moment. The DPF light comes on every other week though. I've been told that it's probably at end of life seeing as it's been on the car for 165k miles. After a short blast on the motorway at 3k rpm, it soon goes.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #17
    Dec 2008
    19 Post(s)
    I removed mine today and letting it soak tonight. I'll refit it tomorrow. 3 hours to get it out. No need for a ramp you can do everything from the top once you remove the bulkhead just behind the engine. Alot of pipes and brackets to remove and a few tricky bolts but doable.
    I removed the DPF while I was at it and that's gone for a full clean as VCDS said it was 3/4 of the way to max ash limit . Cars on 136k miles
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #18
    May 2007
    Quote Originally Posted by liam walsh View Post
    Well, how did you get on?
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #19
    Dec 2008
    19 Post(s)
    Refitted DPF plus EGR cooler and the car is running well now , no faults , no limp mode . Only cost was the DPF clean by DPF Center in Kildimo and coolant. Happy enough now hope it lasts.
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #20
    May 2007
    Fair play Kidd - happy motoring!
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
