Thread: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Dec 2019
    Chorley, Lancashire, UK.
    Hi All,
    New to the forum, apologies if i've posted this in the wrong place.
    I've just picked up a 2010 Passat R-line, with 190k miles on the clock. The car had runaway so i got it cheap, drove it home being extra careful and ready to stall it if the runaway happened. Smoke cleared after a few miles, but i noticed a really bad misfire.
    So, here's what i know:
    • Engine is smooth for first couple of minutes, gets worse the hotter it gets
    • VCDS showing P0300 & P0301 (although P0301 hasn't come back after 15 miles since being cleared but P0300 has returned)
    • Compression in cylinder 1,2,3 showing 400-410psi, cylinder 4 has a snapped plug so can't check that yet .
    • Injector leak off test didn't seem to show anything major at fault, all 4 seem to be returning similar amounts of fuel, but i did it in a rush and couldn't measure exact figures.
    • Flywheel is making an awful chattering noise, which goes with the clutch pressed down (could it be that bad it's causing misfire?)
    • Fuel filter is clean, no metal
    • At idle, the fuel consumption on VCDS is 0.21 liters an hour, and on the 50 mile drive from Rochdale to Chorley, the car returned a whopping 78mpg. My daily driver (another CBDC engine) has an idle of 0.6 liters per hour, so a big difference there.
    • Rpm at idle is bouncing up and down between 750rpm & 820rpm, on my daily driver, it's steady at 805rpm on vcds.
    • Injector values on vcds also fluctuate quite a lot, but never exceed the +2 & -2 specified, but again on my daily driver which was rebuilt 6 months ago, they are quite steady closer to the 0 mark.
    I wanted to see if anyone had experienced anyhing similar, or could suggest what the next steps would be? I think i'm going to pull my injectors from my daily, and test them in this to see if that help, and also the fuel qty valve on the HPFP.
    Below is a link to a video of the misfire when it is hot.
    Bad misfire 2010 Passat B6 CBDC 110 2.0TDI - YouTube
    Any help is much appreciated, i'm hoping this will be a relatively easy fix, as I'd like this to be my new daily driver, it's much more of a looker than my current one.
    Cheers.
  2. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    33 Post(s)
    734 Post(s)
    The +/-2 spec is way to much, anything over 0.5 makes me suspicious but I had this on a Golf 6 CBAB last week and she had put petrol in it. Your problems point to number 1 injector being faulty, it is a very very common failure and can make the MF hammer away.
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  3. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Dec 2019
    Thanks Crasher,
    I was hoping you'd see this post - it may be my first 'proper' post, but after viewing this forum countless times over the years your replies always seem to be knowledgeable and most helpful, certainly helped me fix a number of faults.
    I have a load of spare injector seals, so tonight i'm going to pull number 1 from my daily, and pop it in to see if any change, will update in due course!
    Cheers - Evan
  4. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Jan 2012
    Rustington, West Sussex UK
    6 Post(s)
    65 Post(s)
    Quote Originally Posted by russell2019 View Post
    Thanks Crasher,
    Cheers - Evan
    Common Rail injectors usually have an IMA and will need coding if your daily does not have exactly the same part number.
    Mad Mitch
    1 1 0
  5. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    33 Post(s)
    734 Post(s)
    Quote Originally Posted by DMitch16 View Post
    good point
  6. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Dec 2019
    thanks, I swapped the number 1 injectors round from both cars last night and coded them as required, but unfortunately no change.
    It may be worth noting, that I have pulled the dpf as I thought the misfire was maybe due to too much back pressure from a clogged dpf/cat ( the car had blown a turbo, and a new one put on but I donít think they cleaned the intercooler/piping hence the runaway) but even with the dpf disconnected there is thick clouds of white smoke (mayb blue but canít tell under the led light)
    unfortunately the injector swap made no difference, I actually drove to work this morning with number 1 injector from the bad engine in my daily driver and it was fine.
    im not fully convinced however that one or two of the injectors arenít faulty, going off the fluctuating vcds figures.
    im hoping to properly clean out the intercooler and piping tomorrow, and try my injectors in it, and see what happens then.
    unless anyone has any other ideas what it could be?
    thanks once again
  7. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    33 Post(s)
    734 Post(s)
    Are you sure it does not have some petrol in it?
  8. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Dec 2019
    Hi Crasher,
    Not sure, sorry, but it has 3/4 of a tank left - just how i picked it up last week.
    Any quick tests i can do to check, or is it a case of draining the full tank and filling with fresh diesel?
    I must say, having looked at the fuel filter, it certainly looked as if the fuel was more brown/yellow, rather than the greeny blue im used to seeing in tdi fuel filters. Hadn't even clicked but that could well be the case.
    I'll snap some shots tonight and compare the colours of fuel from my car to this car
  9. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    33 Post(s)
    734 Post(s)
    An olfactory sampling of the filter contents should provide a clue, if in doubt, bilge, flush and refill with fuel of the Devil.
  10. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    Jan 2012
    6 Post(s)
    65 Post(s)
    Or a loose exhaust manifold / naff gasket as that can cause a great deal of smoke?
    Mad Mitch
  1. Passat 2006 2.0tdi (misfire, judder)
    By readyrangers in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-02-2018, 06:55 PM
  2. Question 2010 Passat 2.0TDI Yellow parking brake warning light on no cruise or auto hold
    By wookiebear in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-01-2017, 06:53 PM
  3. Question What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    By tjdayao in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-06-2016, 09:46 AM
  4. How To passat cr camshaft locking tool cbdc needed
    By lee1970 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2013, 08:20 PM
  5. 2.0Tdi DSG passat sport saloon (140PS) - engine noise -
    By Mick_OC1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2009, 02:37 PM
