Thread: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
Results 11 to 20 of 31
  1. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #11
    Apr 2014
    SW London / Surrey
    34 Post(s)
    An olfactory sampling of the filter contents should provide a clue, if in doubt, bilge, flush and refill with fuel of the Devil.
    Would it be feasible to connect a temporary gavity fed supply pre or post filter to test the theory?
  2. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #12
    Jan 2012
    Rustington, West Sussex UK
    6 Post(s)
    65 Post(s)
    Sound logic as isolating the front fuel system and running a clean fuel supply to see if the car runs properly would confirm / eliminate fuel contamination but as Crasher has suggested, a smell test would be the quickest way to find out, unless the OP's sense of smell is compromised.
    Mad Mitch
  3. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #13
    Apr 2014
    SW London / Surrey
    34 Post(s)
    I think it can also be difficult to tell them apart especially when cold unless familiar with various organic solvents, etc as they are largely unseen in liquid form. I don't play with them much, and always have a moment of doubt when putting diesel into car from 20l jerry can that it's the wrong stuff, even though I know it's only the 5l plastic can for lawnmower fuel that has unleaded in it. A few mins at house temp in a shot glass and its a lot easier. They taste very different too .
  4. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #14
    33 Post(s)
    734 Post(s)
    Fuel of the Devil has never passed my lips but I am partial to a smattering of Shell V Power..
  5. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #15
    Dec 2019
    Chorley, Lancashire, UK.
    Hi all,
    so I decided to just drain the fuel tank and filter and put some fresh in, ran for 15 minutes or so at idle but unfortunately no different. What I donít understand is how itís fine for a couple of minutes at cold but then gets worse and worse. I was so set on it being a bent rod but surely it would do it all the time?!
    I went to pull the pan yesterday, but had an absolute nightmare as currently living with girlfriends parents (saving up for a deposit is a tough affair) and they recently had their drive repaved. Needless to say I had tons of cardboard down and rags on hand. Unfortunately the oil container blocked and oil flowed everywhere, so my day was spent cleaning the freshly paved drive rather than inspecting for bent rods .
    any ideas before I set fire to it? Replace all injectors from my daily maybe? Could it be a bent rod still? Even though compression was similar across the three I could actually test? I thought maybe cyl 4 could be bent, but not sure why there would be a p0301 code :/
  6. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #16
    Apr 2014
    SW London / Surrey
    34 Post(s)
    Completely guessing, but have you had a look at what the EGR valves are doing (physically or on VCDS) as the noises change?
    What caused the runaway, and what was done afterwards?
  7. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #17
    Dec 2019
    I did blank the egr with a plate, but no different. The guy I bought it off said it had a new turbo 2 months ago and hasn’t done many miles since so I am under the impression it had a blown turbo and they didn’t clean the piping and intercooler etc but I could be wrong!
  8. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #18
    Jan 2012
    6 Post(s)
    65 Post(s)
    If good injectors still produce a P0301 then this pretty much eliminates an injector fault and means it could be anything to do with the proper operation of number 1 cylinder such as wiring, valves, inlet and compression level which you say is fine, as a result. It definitely seems like it is overfuelling for some reason or another due to the vapour levels being emitted. It is a case of continuing to eliminate one thing after another but fuel trims are important and can be affected by air or vacuum leaks elsewhere, cracked plastic manifolds, and sticky intake valves which gum up over time.
    Mad Mitch
  9. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #19
    Apr 2014
    SW London / Surrey
    34 Post(s)
    Quote Originally Posted by russell2019 View Post
    I was wonderinhg if the EGR cooler could be being operated as you get poorer running. Which bits did you blank / remove? See what you can disscover with a vac pumpon it ?
  10. Re: Misfire - 2010 Passat B6 2.0TDI CR CBDC Saloon
    #20
    Dec 2019
    I havenít had the p0301 code pop back up since I cleared it the night I got the car, only had a p0300 code unfortunately
  1. Passat 2006 2.0tdi (misfire, judder)
    By readyrangers in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-02-2018, 06:55 PM
  2. Question 2010 Passat 2.0TDI Yellow parking brake warning light on no cruise or auto hold
    By wookiebear in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-01-2017, 06:53 PM
  3. Question What can cbdc engine 110 hp vw passat CR 2.0 tdi Turbo can max handle?
    By tjdayao in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-06-2016, 09:46 AM
  4. How To passat cr camshaft locking tool cbdc needed
    By lee1970 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2013, 08:20 PM
  5. 2.0Tdi DSG passat sport saloon (140PS) - engine noise -
    By Mick_OC1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2009, 02:37 PM
