Thread: 2003 A4 Cabriolet - O/S Front Dip Beam permanently on even when lights & ignition off
  1. 2003 A4 Cabriolet - O/S Front Dip Beam permanently on even when lights & ignition off
    Sep 2007
    I have a fault on my ‘53 A4 B6 Cabriolet.
    The off side dipped beam is on at all times, even when light switch to ‘0’ and ignition off.
    (Please note: It is not the parking feature that lets you illuminate one side of car or the other by leaving indicator stalk up or down when you exit car)
    I found some info on the web that suggests it may be a fault in the CEM, a module which controls lights etc and is apparently located under right hand side of dash
    Has anyone experienced this problem?
  2. Re: 2003 A4 Cabriolet - O/S Front Dip Beam permanently on even when lights & ignition off
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Forestier View Post
    Does the post below help?
    https://www.vwaudiforum.co.uk/forum/s...s-on-by-itself
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: 2003 A4 Cabriolet - O/S Front Dip Beam permanently on even when lights & ignition off
    Sep 2007
    All info helps, many thanks.
  4. Re: 2003 A4 Cabriolet - O/S Front Dip Beam permanently on even when lights & ignition off
    1836 Post(s)
    Yes, a faulty relay in the Body Control Module.
  1. Question VW Bora 2003 converting headlights to drive in Europe permanently
    By adamski81 in forum Bora - 1998 - 2005
    Last Post: 28-03-2017, 07:18 PM
  2. Hazard lights stuck on permanently
    By unicronicus in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-03-2017, 08:33 AM
  3. 2003 Polo - red seat light on dashboard permanently on
    By Silverbug in forum Polo - Derby - Lupo - Fox
    Last Post: 11-03-2015, 07:01 AM
  4. Key Fob not opening car however some lights on dash are permanently on!
    By reg6ft3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2012, 01:13 PM
  5. symphony red lights on permanently but no functions
    By jacubu in forum Audi A4 - Archive Topics
    Last Post: 29-03-2007, 09:47 PM
