Thread: A3 1.6tdi (2010) overheating coolant warning light
Results 21 to 30 of 36
  1. Re: A3 1.6tdi (2010) overheating coolant warning light
    #21
    Nov 2019
    Sheffield
    Temp guage going for up from 90c, turn warning comes on. The Temp sometimes doesn't go up and run normal.
  2. Re: A3 1.6tdi (2010) overheating coolant warning light
    #22
    Nov 2019
    Sheffield
    I open window and turn heater off and then temp downs down to normal.
  3. Re: A3 1.6tdi (2010) overheating coolant warning light
    #23
    35 Post(s)
    774 Post(s)
    So the reading on the temp gauge goes above the middle?
  4. Re: A3 1.6tdi (2010) overheating coolant warning light
    #24
    Nov 2019
    Sheffield
    Sorry for very late response (wife had out little girl on 28/01) so been busy.
    Yeah the Temp gauge goes towards top red, never gets there. Been reading and think a coolant flush is the first port of call.
    Which way is easier, the drain plug. Bit have to remove the cover first, or the bottom /top rad hose? If the rad hose way can you get the lower one out without removing anything from the engine bay?
    Regards James
  5. Re: A3 1.6tdi (2010) overheating coolant warning light
    #25
    35 Post(s)
    774 Post(s)
    Which drain plug be that then?
  6. Re: A3 1.6tdi (2010) overheating coolant warning light
    #26
    Nov 2019
    Sheffield
    Lol, should read what I post. The radiator cap, not actually sure what's it's called. The thing at the bottom on the rad that you pull out to allow coolant to flow out.
    Should be under the car, to the left I think on my car, although I have a panel across the full width of the car that I assume we need removing?
  7. Re: A3 1.6tdi (2010) overheating coolant warning light
    #27
    35 Post(s)
    774 Post(s)
    Usually that is a sender, a few had a drain tap. We just pull the bottom hose but I suspect a flush will not help.
  8. Re: A3 1.6tdi (2010) overheating coolant warning light
    #28
    Nov 2019
    Sheffield
    Thanks for your response.
    What would be you first step to sorting it out be?
    Regards James
  9. A3 1.6tdi (2010) overheating coolant warning light
    #29
    Near Blackpool
    21 Post(s)
    Thermostat and water pump? But Iím sure that was suggested at the beginning of this saga.
    Check rad fans work and confirm temp sender is reporting correct temp would also be on my list to tick off
  10. Re: A3 1.6tdi (2010) overheating coolant warning light
    #30
    Nov 2019
    Sheffield
    Thank for that. I was thinking it maybe temp sensor.
    Is their anyway to find out if thermostat is working, other than removing it from the car?
    Regards James
  1. Please Help Overheating warning light
    By eastmidsdude in forum Golf MK7 - 2013 - 2019
    Last Post: 05-04-2019, 02:00 PM
  2. Question 2010 VW bulb warning light issue
    By CsidgeVW in forum Chat - Anything with wheels
    Last Post: 10-04-2018, 08:32 PM
  3. Engine Fault Warning Light - 1.6TDi
    By Bob_S in forum Golf MK6 - 2009 - 2013
    Last Post: 07-05-2017, 08:11 AM
  4. Egr touran 1.6tdi cr 2010
    By Runel77 in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2016, 09:15 AM
  5. 2010 passat fault warning light
    By Castrol1450 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-07-2013, 06:16 AM
