Thread: Before I set fire to my Audi A6
  1. Before I set fire to my Audi A6
    Jan 2020
    Bath, England
    Hi All,
    Last week my car (Audi A6 C6 Avant 2007 2.0 TDI) Started juddering, hesitation between 1500-2000rpm. Before you all scream MAF issues at me, I have now fitted 2 new ones, a cheapish one from Europarts and a Bosch one. Both produced the same result i.e. nothing! Still that same issue. I have now had to disconnect the MAF as its driving me crazy. The car drives fine without the MAF using basic ECU MAP.
    What the hell is going on with it, its had a new EGR in the last month, and the only fault I get is 00257 MAF Implausible signal.
    I have also changed the Air and fuel filter.
    Please help before I give it a damn good thrashing!!!!
  2. Re: Before I set fire to my Audi A6
    1837 Post(s)
    Aftermarket Air Mass Meters are a pain, genuine only. A faulty EGR unit can cause this problem though so what was fitted, cheap and nasty?
  3. Re: Before I set fire to my Audi A6
    Jul 2008
    Lisburn
    15 Post(s)
    ok so you changed the sensor for a bosch and is save for now to assume as good - does the signal get to the ecu? ie broken or worn through wires?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Please Help Audi A4 1.8T 1996 window fire consequences
    By smee3041 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-05-2014, 10:53 AM
  2. Audi A3 2.0 tdi dsg does'nt fire up
    By reece-elec in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-10-2009, 02:06 PM
  3. Please Help Audi A4 wont fire
    By abaker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2009, 10:46 PM
  4. Audi Missed Recall On A6 Leads To Fire
    By loyal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2007, 06:18 PM
  5. audi 80 tdi mis-fire
    By Benny in forum 80 - 90
    Last Post: 27-01-2007, 06:57 PM
