Thread: Passat B6 estate boot lock issue
Results 1 to 10 of 10
  1. Passat B6 estate boot lock issue
    Mar 2019
    Hi All
    First post on this forum
    I have a problem with passat b6 estate boot lock. It was stuck but I managed to open from emergency release latch. Checked on VCDS and got a code for boot lock fault. I bought one used and replaced it. After replacing mechanism, fault code is gone but boot still doesn't open with key, driver door or release handle.
    Micro swith works but boot wont open. With VCDS, mechanism (central locking) motor operates but boot still dont open. It only opens from emergency release latch.
    I've stripped loom where it enters into car body and couldn't find any wire broken.
    Any idea what it could be ?
    Any help will be appreciated
  2. Re: Passat B6 estate boot lock issue
    Mar 2019
    Any ideas please ?
    Any help will be much appreciated
  3. Re: Passat B6 estate boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Coild it habe been jammed shut or run into, and distorted al8gnment a bit? If you open the boot then use a solid bar like acrewdriver shaft to mimic the staple the latch closes against will it release when free of friction / tightness?
  4. Re: Passat B6 estate boot lock issue
    Mar 2019
    Thanks for your reply
    It doesn't open even with boot open but mechanism locked by hand
  5. Re: Passat B6 estate boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    It's one of the electrical realease types I'm assuming. Do you hear or feel any signs of life when triggering release from VCDS? Bit of a twitch? Groan of motor taking up strain against gears?
  6. Re: Passat B6 estate boot lock issue
    Mar 2019
    Yes , when I open with VCDS, motor operates
    And if I supply 12V direct to pin 4, motor operates but it doesnt unlock
    Weird!
  7. Re: Passat B6 estate boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    I know it's difficult to join up descriptions and reality with a lot of these things.
    Reading you first and most recent post you seem to be saying when the latch motor operates on your 2nd hand / breaker unit it doesnt open the boot. That sounds like a broken latch mechanism. If it sounds unstrained then I'd guess the drive gears are broken in a disengaged from load way. If it sounds laboured maybe broken teeth or jammed part of drive. If the last of those a good spray with lubricant could help. I'd try grease first, and operate manually a few times. Then WD40 if necessary.
  8. Re: Passat B6 estate boot lock issue
    Mar 2019
    Thank you for your reply
    Yes you are right. Motor operates with VCDS but doesnt unlock the door. While when I try to.open boot manually with release switch, then motor doesn't operate. Nothing happens. I've checked release switch, its working. And wiring is intact.
    Weird ? Isnt
  9. Re: Passat B6 estate boot lock issue
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    How did you check the release switch?
    Do you still have the old latch, and does its behaviour offer any clues?
    As before, when the motor moves is it a swift, unloaded whizz, whizz sound. Or a more laboured, loaded effect?
  10. Re: Passat B6 estate boot lock issue
    1836 Post(s)
    Only the estate suffers from this, only the estate has a wiper motor with a washer jet fitting directly above the lock unit and screen wash water contains salt... the fitting and the motor leak and are made by Valeo, why VAG stick with Valeo can only be down to price as everything they make falls to bits.
  1. Please Help B5.5 Passat Estate Boot Lock popping open when locking car
    By Preece in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2023, 12:24 PM
  2. Please Help Boot Lock Issue
    By barachello in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2015, 10:22 AM
  3. Question Boot lock issue
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2012, 03:39 PM
  4. Passat estate boot lock fixed
    By jenny35 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2011, 07:33 PM
  5. Boot Lock Issue
    By mrecho in forum Passat - Archive Topics
    Last Post: 04-02-2008, 02:23 PM
