Thread: a6 c7 avant rear washer
Results 1 to 10 of 11
  1. a6 c7 avant rear washer
    Jun 2012
    whitland uk
    hi guys me rear washer is not working ,pump is going ,jet is clear ,i removed jet thinking it needed cleaning but it is fine ,tried to get water to work with jet removed ....nothing came out .i have looked in boot side storage areas nothing is wet ..any ideas ???
  2. Re: a6 c7 avant rear washer
    Port Talbot, South Wales
    36 Post(s)
    I have the same problem
  3. Re: a6 c7 avant rear washer
    May 2008
    31 Post(s)
    I have no idea but will offer the following suggestions,
    1, Buy a land rover and washers will be the least of your worries1
    2, I have seen washer pumps with a built in filter gauze, had to rmeove pump to access the gauze
    3, I have seen rear wshers not used for so long the washer fluid/additive had gone hard in the pipework
    4, If fitted the non return valve may have failed, in which can it will take some time for the fluid to pump all the way to the rear
    5, On some cars one pump does front and rear apparently by running backwards, might be worth looking at?
    6, Pipe may be kinked where it enters the rear tailgate or even be blanked off
    1 1 0
  4. Re: a6 c7 avant rear washer
    Mar 2014
    Aylesbury Bucks
    10 Post(s)
    Aaaand, the pipe running to the rear may have disconnected at one of the joints due to freezing.
    Run the rear washer for a while, and if the reservoir has gone down, but nothing out of the jet, lift the carpets and prepare for a flood!
    On the C5, the main culprit is the A pillar in passenger side floor. C7 may be similar...
    I mopped out 5 litres of green screen wash from my C5
    1 1 0
  5. Re: a6 c7 avant rear washer
    Jun 2012
    whitland uk
    i can not see any washer fluid on the ground anywhere ,or inside boot area/tailgate ,does anyone have any pics as to where all the joints in the pipe are and how many are there so i can start removing trim to investigate. in the front some say front inside "a" pillar passenger side others say under wheel arch trim .this is the a6 avant c7 2012 on... any help
  6. Re: a6 c7 avant rear washer
    Feb 2016
    Blaydon, North east England
    50 Post(s)
    Washer bottle is behind the front passenger wheel inside the wheel arch.
    Jack car up, remove wheel and inner wheel arch, you will see it there. I've had mine out on my Allroad due to stagnant water smell. Easy to come out, takes about 20mins
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
    1 1 0
  7. Re: a6 c7 avant rear washer
    Jun 2012
    whitland uk
    cheers it gives me somewhere to start now ..just waiting for weather to warm a bit and i can have a look at pump etc and move on from there trying to find the other joins in the pipe to see if they have pulled out or blocked
  8. Re: a6 c7 avant rear washer
    Jun 2012
    whitland uk
    ok now i have water right up to boot have taken off pipe to wiper motor water floods out with pump on wash jet is off but still no water coming out any ideas ???
  9. Re: a6 c7 avant rear washer
    Aug 2018
    Swindon
    8 Post(s)
    blockage in the last bit of pipe / washer jet ....
    2014 Audi A6 Allroad (C7, 245bhp)
  10. Re: a6 c7 avant rear washer
    Jun 2012
    whitland uk
    Quote Originally Posted by OmegaV6 View Post
    washer jet is clear and taken off .have pushed wire down hole in centre of wiper shaft about 2-" . does anyone know how to take of black plastic piece inside on wiper motor where the pipe fits on ??
  1. A4 Avant - Rear Washer Bottle / Motor / Washer Pipe routing
    By mumutley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2013, 09:18 PM
  2. A4 Avant rear washer
    By Google44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2013, 11:38 PM
  3. Question Rear washer jet, Avant 80 tdi
    By palaemon in forum 80 - 90
    Last Post: 07-02-2010, 03:14 PM
  4. Help!!Rear Washer A6 Avant
    By A618T in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-12-2009, 02:47 PM
  5. A6 Avant rear washer
    By agsy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2009, 09:15 AM
