Thread: VW Polo 1.4 TDI CUS/CUSA Engine Failure
  1. VW Polo 1.4 TDI CUS/CUSA Engine Failure
    Jan 2020
    Anglesey
    Hello, Just wondering whether anyone can shed some light on this problem. Have a Polo 1.4 TDI engine code CUS that came in with a pretty loud banging noise near the gearbox. Suspected the DMF, removed starter motor and the flywheel was very loose and noisy. Have fitted a new VW solid flywheel kit, re-started engine and the flywheel was quiet but there is a heavy noise from the bottom end of the motor. Stripped the sump off, and number 3 big end has a lot of play in it, so it must have been starved of oil. Plugged in diagnostic scanner, and there is one fault code only relating to an incidence of low oil pressure (historic, not current). Suspect the customer has been driving around for some time with a worn DMF, is there a chance that the vibration may have caused partial failure of the oil pump, or affected number 3 big end somehow? It was full of oil, has a fsh (last done 3 months ago) and has only done 40k, 2015 car. If anyone has some ideas or suggestions that would be appreciated. Thanks.
  2. Re: VW Polo 1.4 TDI CUS/CUSA Engine Failure
    Nov 2019
    Peterborough
    Is it possible the dmf noise was masking the new noise?
  3. Re: VW Polo 1.4 TDI CUS/CUSA Engine Failure
    33 Post(s)
    734 Post(s)
    Yes I have seen faulty DMF’s take cranks out, even snap them, you could do with finding and reading TPI 2039968, I will see if I have it.
  1. polo pedal box failure
    By 25annigolf in forum Polo - Derby - Lupo - Fox
    Last Post: 30-04-2009, 06:28 PM
  2. Important 05 Polo 130 GT Airbag failure
    By JVOB in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2009, 08:23 AM
  3. Polo MOT failure on exhaust emissions
    By slund in forum Polo - Derby - Lupo - Fox
    Last Post: 28-01-2008, 04:31 PM
  4. Polo TDI Turbo Failure
    By Dupz in forum Polo - Derby - Lupo - Fox
    Last Post: 24-12-2007, 02:53 PM
  5. Polo Indicator Failure
    By oihiggsy in forum Polo - Derby - Lupo - Fox
    Last Post: 25-06-2007, 02:31 PM
