Hi all,
Just passed 90k and decided to change the plugs. Engine is CCZB 210bhp. No error codes.
Took the old out and replaced with NGK PFR7S8EG.
Didn't actually look at what I took out and they've since gone in the bin
I torqued the plugs to spec and put everything back together.
I've since noticed a drop of around 3-4 mpg, even taking it easy on the motorway.
  • Are the PFR7S8EG likely to be what was put in at factory?
  • Should I have checked that they were correctly gapped (probably yes)?
  • Does anyone have opinions on what plugs I should have put in or are these correct?
  • Anything else I should check that might be causing high consumption?
I also know that this isn't the worlds most efficient engine... I would just like my 'economy' back to normal.
Thanks a lot.
