Thread: Egr codes appearing. Possibly a vacuum issue?
  1. Egr codes appearing. Possibly a vacuum issue?
    Birmingham
    6 Post(s)
    I have an allroad c5 2004 2.5tdi. I have had a couple of issues where my Mil comes on and the code indicates an egr insufficient flow error. I have cleaned the egr valve. Not that it was dirty really, and used a vacuum generator to test the diaphragm. All seems OK. The light reappeared on the way home today so that hasn't cured it. I had wondered whether the vacuum pumps deteriorate on these engines. Should I be checking it. If so what pressures make for a good or bad pump. This also had me wondering if the check valves in the vacuum connection to the servo ever fail. I need to replace mine anyway as I broke off one of the nipples where the small hose attached. I have looked at elsawin but I can't see a procedure for testing any of the vacuum system.
    Any body else had similar issues?
    Thanks Mike
  2. Re: Egr codes appearing. Possibly a vacuum issue?
    Jan 2015
    Israel Kfar uriya
    8 Post(s)
    If there is a problem with the vacuum pump then the brake pedal will be very hard to stop and the turbo cannot provide the necessary pressure either.
    Check out the N18 (the EGR Operator) and Vacuum Tubes
  3. Re: Egr codes appearing. Possibly a vacuum issue?
    30 Post(s)
    708 Post(s)
    I would suspect the solenoid if there are no vacuum leaks.
  1. Please Help A3 2000 1.9 tdi 110 vacuum issue, car hesitates
    By no_endo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 13-07-2015, 06:47 AM
  2. Please Help 4motion Breaking Issue (Possibly)
    By SG77 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-03-2011, 08:15 PM
  3. Question Low Turbo / Heavy Brake - Vacuum Issue?
    By themuttons in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2011, 03:02 PM
  4. Question Possibly the dreaded Injector issue?
    By tobetrue123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-11-2010, 06:29 PM
  5. Boost issue possibly resolved.
    By Ben in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:03 PM
