Thread: ESP/ABS/TPMS fault after carrying heavy load
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: ESP/ABS/TPMS fault after carrying heavy load
    #11
    Aug 2019
    Harrogate
    Quote Originally Posted by Odee View Post
    TPMS, ESP, ABS, stop/start and parking brake warning lights are all linked to a failure of a speed sensor at a hub. The failure may be the electronic speed reader or the sensor disc which is part of the wheel bearing.
    You could have tried to carry too much weight and now have knackered the bearing.
    John.
    Is it easy to see if the bearing has gone?
    Would it appear cracked or such?
  2. Re: ESP/ABS/TPMS fault after carrying heavy load
    #12
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi. Have you cleared the fault codes ? I would do that before you start worrying about something that may not be a problem, your high load may have upset some perimeter causing the codes but no damage done to any component. I would think there is a good chance they will not come back, if the do then look into what is faulty.
  1. Smoke under heavy load - any thoughts on cause please?
    By Rustychain in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-02-2019, 08:44 PM
  2. TPMS fault
    By juice in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 01-04-2017, 06:10 PM
  3. 2002 A4 Avant Quattro - load carrying capacity.
    By Brahan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-06-2016, 01:54 PM
  4. Avant and heavy load
    By fernar in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-01-2013, 12:08 PM
  5. Allroad 2.5 tdi - squealing noise under heavy load
    By craig_ in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2012, 08:44 AM
abs, esp
