Thread: C7 A6 Avant Xenon Headlight Aim Issue
Results 1 to 10 of 11
  1. C7 A6 Avant Xenon Headlight Aim Issue
    Jan 2020
    Yorkshire
    Hi all,
    New to the forum and a big hello from Yorkshire!
    I've recently bought a "63" plate A6 Avant black edition pre face lift with Xenon lights.
    Driven it for the first time this week in the dark and the dipped beam is aiming very high! Every other driver keeps flashing me!! For the time being I've enabled the "driving on the right setting" which had dropped the beams and only got flashed a couple of times since. It's just passed it's MOT. I also have a "13" plate A3 s-line with Xenons and have compared the aim and confirms the A6 is aiming high. When the car starts up it does the who "up & down" xenon thing and both lights are aiming at the same height.
    I've made the garage that I bought it from aware of the issue. Whilst they deal in high end cars, they are not audi specialists so I'm not holding out for a quick fix.
    So what could I try/check in the meantime? A read on various forums suggests there are adjustment screws in the headlights? However, some have said that unless the lights are in an "adjustment" mode with VCDS that will just mess everything up.
    Another suggestion was to check the tie rod for the light level sensor but I'm struggling to find a definitive answer as to where it's located on a C7 avant....front or rear or both? If so, where?
    Anything else I can check myself on the drive? I dont have VCDS at the moment...
    Should also add the car isnt flagging any warning messages.
    Thanks in advance.
  2. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jul 2016
    Chestfield kent
    57 Post(s)
    Hi. If the dealer you purchased from are happy to resolve free of charge to you, I would let them get it sorted, even if they get it done by Audi. If you start messing around they may not want to play ball. Show them evidence if the beam being high with photos comparing it to your other car. Give them the chance to resolve this first befor you do anything else. Good luck.
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  3. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jan 2020
    Yorkshire
    Ok Iíll do that then. I suppose I was to save myself and the dealer the hassle and time given they arenít local to me.
    Do the A6 xenons generally aim quite high anyway. Research suggested this might be the case and simply running over minor bumps in the road may look like Iím flashing other road users.
    Given the car is new to me, and Iíve driven other cars with Xenon/LEDs and never had this issues, I was looking for a bit of feedback?
  4. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Aug 2009
    Near Lanark
    21 Post(s)
    I have a 2014 A6 with xenons and my lights don't aim high at all.
    I did need a headlamp replaced by the dealer not long after I bought the car but in failsafe mode, the light aims very very low to avoid dazzling.
    Not sure why it would aim high... Possible stuck sensors??
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  5. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Oct 2019
    Peterborough, England
    16 Post(s)
    Does your car have the self-levelling suspension and auto-adjusting lights?
    So, when you turn the engine on, the Xenons come on and lights adjust up and down - as if settling down - and then sit still?
  6. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jan 2010
    Yate UK
    13 Post(s)
    Quote Originally Posted by A8Cruiser View Post
    I think the Xenons are auto adjusting (legal requirement) whether you have self levelling suspension or not, based on my previous A6.
    And the normal setting is not high by any means so this does sound like a glitch.
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
  7. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jul 2016
    Chestfield kent
    57 Post(s)
    Hi "I think the Xenons are auto adjusting (legal requirement) whether you have self levelling suspension or not, based on my previous A6."
    think this is correct, my 2003 TT has BiXenon lights and dose an adjustment when I turn them on. A6 Has LED which also go through movement when turning on.
  8. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Oct 2019
    16 Post(s)
    Do the lights go up and down when you turn on though?
  9. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jan 2013
    Wessex. and Southern France
    78 Post(s)
    If the sensor on the suspension is borked it should put up a code, mine did.
  10. Re: C7 A6 Avant Xenon Headlight Aim Issue
    Jan 2020
    Yorkshire
    I got sorted in the end. The lights for some reason were just set too high.
    Auto Technica in Hull sorted it for my. Diagnostics confirmed everything was behaving and they adjusted them back down to a reasonable level.
  1. A4 - B9 Headlight Xenon or bi-xenon
    By martinbuffleo in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 31-01-2017, 09:56 PM
  2. Question B6 Avant Xenon Headlight Conversion
    By onlyfools in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2014, 09:22 AM
  3. Main beam xenon headlight issue
    By Coxy789 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-10-2013, 12:39 AM
  4. Xenon Headlight on A6
    By Hollean in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-12-2012, 01:42 PM
  5. xenon headlight help please
    By A4 FFS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-10-2012, 04:35 PM
free web
stats
