Thread: Unusual Exhaust Leak
  1. Unusual Exhaust Leak
    Apr 2010
    uk
    During really cold weather when the outside air temperature is around freezing I get a whiff of exhaust gas when I fire up from cold and it would appear to be coming from close to the dpf / turbo area, I have even seen a little exhaust smoke puffing up from the back of the bonnet. There are no leaks when hot or on hot start up situations.
    Ever heard of similar leak? It's a 2ltr diesel
  2. Re: Unusual Exhaust Leak
    May 2012
    Birmingham Uk
    Try tightening the clamp bolt. I had the same problem with mine, it was a couple of turns loose. Good luck.
  3. Re: Unusual Exhaust Leak
    Dec 2015
    Scotland
    11 Post(s)
    I've had exactly the same issue, I think there is a flexi pipe that breaks, the clamp rots or it detaches - I'm not sure. However I started getting a noisy blow from the area and a local garage fixed it for free in about 5 minutes! I originally had an issue with a connection here which way back was fixed under warranty!
    Audi A6 2008 Saloon Sline 2.0 Tdi BRE
    Vw Passat B7 1.6 tdi 2012 estate
    Previously - 2008 1.6 tdi Mini, 2006 Mazda Mx5 1.8, 2002 Vw Golf 1.9 tdi SE, 2010 Bmw 318d Msport, 1992 Porsche 944 2.5 turbo, 1986 Porsche 944 2.5 NA, 1984 Porsche 944 2.5 NA
  4. Re: Unusual Exhaust Leak
    1840 Post(s)
    Yes the circular clamp being loose is common, sometimes it happens when the DPF has been off and the clamp/seal has not been replaced.
  5. Re: Unusual Exhaust Leak
    Apr 2010
    uk
    Thanks for the replies, i've not been on here in months. It went in for it's mot way back in mid January 2020 and eventually passed without any mention of a leak. As the weeks went by it stopped leaking but sure as night follows day the small leak returned when the weather turned frosty.
    Now it's test time again so I will take it for a good high speed run to warm it up before the test and see how it goes.
    Since lockdown started in March last year I have only filled the tank three times.
  1. Replies: 0
    Last Post: 16-08-2016, 08:31 PM
  2. Unusual engine / exhaust noise with tepid diesel
    By divsec in forum Golf MK7 - 2013 - 2019
    Last Post: 26-09-2013, 09:20 PM
  3. Please Help Exhaust downpipe leak
    By Dqaff in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2012, 09:13 PM
  4. Please Help Exhaust Leak only when cold
    By nsimmo in forum Golf MK4 - 1999 - 2004
    Last Post: 16-08-2011, 08:59 AM
  5. Coolant Leak in to exhaust?!
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2007, 10:30 PM
