Thread: 1996 1.8 T cranking time before start
  1. 1996 1.8 T cranking time before start
    Mar 2016
    Minervois, France
    37 Post(s)
    As it takes so little time, and is so easy to do now I have the equipment, I randomly check the fuel pressure from time to time, after problems with a faulty fuel pressure regulator (FPR).
    By separating the system on each side of the union where the feed hose joins the fuel rail during the test, by means of a couple of shutoff valves, I find that pressure on the rail, which includes the injectors and the FPR, is held indefinitely, and that there is a slow leakage back to the tank via the fuel pump and its check valve. I can live with the latter, as it does not affect the fuel pressure when the engine is running.
    However, the engine has always taken longer to start when it has been standing for some time. I now know that this is because the fuel pump does not run until the starter motor begins to turn. In fact, the engine does not fire until the fuel pressure reaches about 3 bar.
    My Alfa's fuel pump runs for about a second when the key is turned to the "Run" position. This is long enough to make sure the fuel pressure is at the set value before the starter motor begins to turn, and the engine starts immediately.
    I thought about modifying the Audi's wiring so that the fuel pump runs as soon as the key is switched on, in order to get a quicker start.
    However, I then thought that perhaps it is better for the engine to make a couple of turns before it fires, so that the oil pump has had a chance to prime, and start to feed at least some oil to the system, particularly to the crankshaft bearings, so decided to leave things as they are.
    Any thoughts on that?
    Don't force it - get a bigger hammer!
    1996 A4 B5 Avant 1.8T engine code AEB automatic with 66,000 kms - 41,000 miles on 16/09/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  2. Re: 1996 1.8 T cranking time before start
    Mar 2019
    Middlesbrough, England
    Ignition amplifier is on its way out
    Sent from my MAR-LX1A using Tapatalk
  3. Re: 1996 1.8 T cranking time before start
    Mar 2016
    Minervois, France
    37 Post(s)
    Quote Originally Posted by robbobjm View Post
    Possibly, thank you.
    However, testing and work on the FPR was last year, and no problem now. See this thread
  1. Replies: 17
    Last Post: 01-03-2019, 02:56 PM
  2. Allroad 2.5 2005, drop in economy, flat performance, longer cranking on cold start
    By A. Waterfield in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-08-2015, 03:39 PM
  3. 2.0tdi cranking but won't start..
    By Messer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-12-2012, 10:13 PM
  4. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    By kezia in forum Early Passat Forum - Pre 97
    Last Post: 07-01-2008, 02:44 PM
  5. Passat 1996 1.9 Dti Will Not Start ???????any Help Please
    Last Post: 06-01-2008, 08:08 PM
