Thread: Instrument Cluster Error Codes
  1. Instrument Cluster Error Codes
    May 2013
    Rugby, UK
    12 Post(s)
    Hi All,
    My son has a 2012 8P (one of the last). In September he had the dreaded instrument cluster failure, with all instruments failing and immobiliser cutting in so no start, which has been repaired.
    All OK until last week, but now it intermittently goes into limp mode.
    He has had it checked for error codes and it is coming up with:
    00003 - Control Module - Sporadic 014 Defective
    00779 - Outside Air Temp Sensor - Sporadic 010 Open Short to Plus
    00771 - Fuel Level Sensor (G) - Sporadic 010 Open Short to Plus
    Can anyone shed some light on this please? Is it a software issue, or does it need more repair?
    Thanks!
    2017 model A6 Avant Black Edition 3.0Tdi (272) Quattro, Sepang Blue Exclusive Paint, Tech Pack, Matrix LEDs, Ambient Lighting, 20" 5 Twin Spoke Wheels, S Line Suspension, Audi Smartphone Interface, Debadged
  2. Re: Instrument Cluster Error Codes
    Near Blackpool
    48 Post(s)
    Have you got the full fault code scan as you’ve put control module fault code but not what module it’s failed on.
  3. Re: Instrument Cluster Error Codes
    May 2013
    Rugby, UK
    12 Post(s)
    Thanks for your reply jonathanfenton
    This was read using a VS450 scanner, so it's all the display shows
    00003 - 110 Can Bus 01/03 - Control Module - Sporadic 014 Defective
    00779 - 043 Can Bus 02/03 - Outside Air Temp Sensor G17 - Sporadic 010 Open Short to Plus
    00771 - 042 Can Bus 03/03 - Fuel Level Sensor (G) - Sporadic 010 Open Short to Plus
    Does that help?
  4. Re: Instrument Cluster Error Codes
    Near Blackpool
    48 Post(s)
    Have a look on the VCDS map and see if someone local to you can scan it.
  5. Re: Instrument Cluster Error Codes
    May 2013
    Rugby, UK
    12 Post(s)
    Quote Originally Posted by jonathanfenton View Post
    A quick update on this issue. Tried to contact local forum members with VCDS and unfortunately no responses, so took to my local independent Audi specialist, who scanned and confirmed EGR valve failure. They recommended taking to Audi for a scan etc. because we had the emissions software update done and this is known to kill the EGR valve, and Audi had been offering goodwill.
    Long story short, Audi confirmed EGR valve failure, but as the emissions software update was over 2 years ago, no help or goodwill offered from Audi UK. Quoted £1,250, reduced to £1,050 for dealer goodwill.
    In the end, took back to the local Audi specialist and fixed for £730 all in.
    Now running perfectly.
  1. Please Help Instrument cluster error problem
    By Reddukem in forum Leon
    Last Post: 18-07-2019, 09:47 AM
  2. Instrument Cluster LCD
    By nema0825 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-04-2012, 09:13 PM
  3. Instrument cluster
    By pricey01 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2011, 08:06 AM
  4. B7 instrument cluster in a B6?
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2009, 07:13 PM
  5. Instrument Cluster
    By j4s0n88 in forum VCDS - General Questions
    Last Post: 03-10-2008, 06:36 PM
