Thread: 3.0 v6 A4 - front engine mount
  1. 3.0 v6 A4 - front engine mount
    Liverpool
    11 Post(s)
    Have just noticed the rubber donut on the front lower engine mount on my 2003 3.0 is perished, searched and only found what looks like a replacement rubber donut, not the whole thing? (both parts of the bracket) is it normal just to replace the rubber donut, or the whole thing?
    And, if i should replace the whole thing, wheres best to order one from? ECP done list anything at all....
  2. Re: 3.0 v6 A4 - front engine mount
    Jan 2009
    Birmingham
    35 Post(s)
    just replace the rubber snub mount
  3. Re: 3.0 v6 A4 - front engine mount
    Jan 2009
    Birmingham
    35 Post(s)
    part number is 8E0199339
  4. Re: 3.0 v6 A4 - front engine mount
    Liverpool
    11 Post(s)
    Thanks arman123, yep got the rubber insert from ECP and fitted today, perfrct
    cheers pal
  5. Re: 3.0 v6 A4 - front engine mount
    Nov 2008
    Leeming
    How long did it take ? Did you have to put the car in service position (as if changing belts)
  6. Re: 3.0 v6 A4 - front engine mount
    Liverpool
    11 Post(s)
    Didn’t are too long Blackpool, but we did have it in service position to change the power steering belt so can’t say if it needs to be in service position or not
    was easy enough to do, 7 or 8 bolts and both metal parts come off, and the perished remains of the mount rubber itself dropped out like a half eaten donut ��
  1. Changing front engine mount
    By 54A4Avant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-01-2018, 09:16 AM
  2. Question front engine mount, broken or ok to use?
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2014, 09:27 PM
  3. Question Front engine mount
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-07-2012, 02:57 PM
  4. How To Replace the front engine mount at a 35i
    By Dr944S2 in forum Early Passat Forum - Pre 97
    Last Post: 21-11-2011, 10:46 PM
  5. front engine mount
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-03-2009, 10:04 PM
