Thread: coding a new instrument cluster
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
  1. coding a new instrument cluster
    Mar 2009
    Crewe Cheshire
    6 Post(s)
    I have an audi a3 8p 2006 2.0 tdi which the central locking doesnt work , Audi main dealers say it is a fault with the instrument cluster and its 1700 for a new one , if I buy a used one does anyone know who in cheshire or nearby can code it to my car so I can just swap it over ?????
  2. Re: coding a new instrument cluster
    Near Blackpool
    20 Post(s)
    98% sure you have to code it as it forms part of your immobiliser.
  3. Re: coding a new instrument cluster
    Mar 2009
    Crewe Cheshire
    6 Post(s)
    That's what I am asking , I know it needs coding to the car , I need someone who can do it ????
    Sent from my Pixel using Tapatalk
  4. Re: coding a new instrument cluster
    Near Blackpool
    20 Post(s)
    Sorry read your post as a question of if it needed coding. Any decent VAG specialist with the full VAG suite that connects to VW can do it, I forget itís name.
    Volkservice in blackpool did my ECU swap for me
  5. Re: coding a new instrument cluster
    33 Post(s)
    729 Post(s)
    The Audi dealer says the convenience system fault is to do with the instruments! I can’t see that....
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  6. Re: coding a new instrument cluster
    Near Blackpool
    20 Post(s)
    There was a similar post recently and the instrument gave a rom error and that caused central locking to fail didnít it. Could do with a full fault scan out put.
  7. Re: coding a new instrument cluster
    33 Post(s)
    729 Post(s)
    I can’t see it BUT I have had two instances recently where fitting a new BCM recoded the ABS ECU for no good reason.
  8. Re: coding a new instrument cluster
    Mar 2009
    Crewe Cheshire
    6 Post(s)
  9. Re: coding a new instrument cluster
    Near Blackpool
    20 Post(s)
    Fair enough, so your back to either getting your current instrument cluster repaired which is like pinning a tail on a drunk donkey in the next room blindfolded when it comes to picking a repairer or getting a scrapper recoded. When you get a new cluster you plug it in to the vag computer and it goes ok you need to fix that by replacing, you put new or second hand one in and it recodes it all magically. Impressive kit, suppose it should be when they make the kit and car lol. Only people I know with it is Volkservice in Blackpool.
  10. Re: coding a new instrument cluster
    Mar 2009
    Crewe Cheshire
    6 Post(s)
    Spoke to a couple of local vw Audi indy specialists and none of them will do it with a second hand cluster , they will do it with a new one but so will Audi for half an hour's labour cost , it's the cost of a new cluster that is 1700 quid !!!!!
    Sent from my Lenovo TB-X704F using Tapatalk
  1. instrument cluster
    By carcav in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-07-2018, 12:27 PM
  2. New instrument cluster coding.
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-06-2013, 06:42 PM
  3. Instrument cluster
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 05:25 PM
  4. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  5. Instrument Cluster Coding HELP!
    By nisiotis in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2008, 11:18 AM
