Thread: coding a new instrument cluster
Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
  1. Re: coding a new instrument cluster
    #41
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by stephenwhite990 View Post
    ... I cant see anywhere on vcds to get the key to open all doors and disarm the alarm , it locks all doors and sets the alarm on the key ???
    I think these are the screens I use to set those up on the Central Convenience module.
  2. Re: coding a new instrument cluster
    #42
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    My selective single door opening is unticked and the alarm delay I have tried 0 and 1 and it makes no difference at all , I still gte just the drivers door unlocking with the key
  3. Re: coding a new instrument cluster
    #43
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    See if the rest of the coding looks similar in the 12 little boxes of pic 1. Might be some other thing overriding it.
    If little unlock button on door is working (or the "unlock all doors when key removed") then at least central convenience unit / module can command door units (and you should be able to test that via VCDS output tests). Overall though isn't this still sounding like a CCU problem, and not instrument cluster?
  4. Re: coding a new instrument cluster
    #44
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    A few Q:
    1) Has the remote and / or key unlock all doors ever worked?
    2) Have you tried disconnecting and reconnecting the battery 20 mis later? There are reports elsewhere of the CCM needing a bit of a rest from power to untangle itself sometimes.
    3) Is the battery healthy? Similar to 2 - low battery / power saving mode (if present) can make odd things happen.
  5. Re: coding a new instrument cluster
    #45
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Yeah the little button on the drivers door works to unlock the doors , the car auto locks the doors at 15mph ok and unlocks all the doors when the key is removed from ignition , I will have another look at the coding and take some screenshots later
  6. Re: coding a new instrument cluster
    #46
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Yes the remote used to work fine to unlock and lock the car then it just got worse ie sometimes I would be pressing the remote 10 times to lock it , then it just stopped working all together via the remote , before it stopped working I never used the key to unlock the car so I dont know if that ever unlocked all the doors . Battery is healthy
  1. instrument cluster
    By carcav in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-07-2018, 12:27 PM
  2. New instrument cluster coding.
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-06-2013, 06:42 PM
  3. Instrument cluster
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 05:25 PM
  4. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  5. Instrument Cluster Coding HELP!
    By nisiotis in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2008, 11:18 AM
